Lost Motion Assembly...
Old Mar 21, 2002 | 10:44 PM
h46it's Avatar
Default Lost Motion Assembly...
I was wondering what does that LMA really do??? I heard that it cuts down the noise of Vtec??? Is this true??? But I am also wondering, does anyother B-series head??? b16a, b18c, and b16b??? Can anyone help me out!!??
Old Mar 21, 2002 | 10:48 PM
Reid's Avatar
Global Moderator
Default Re: Lost Motion Assembly... (h46it)
No, LMAs will not make VTEC quieter. It may reduce valvetrain noise in some cases though.
Not quite sure what you're asking here.
Old Mar 21, 2002 | 10:54 PM
h46it's Avatar
Default Re: Lost Motion Assembly... (Reid)
well my main question is that i have a b16a head. I was going to be installing ctr cams...is it necessary to have the LMA??? Also, they say that it helps valve springs???
Old Mar 22, 2002 | 05:20 AM
rolow's Avatar
don't b16 have them to?
How much is a new set?
theres a guy on ebay selling them for $99 is that good?
Is it worth upgrading when i put in my new cams?(99 si head)
sorry for butting in on your thread but I've had the same ?'s
Old Mar 22, 2002 | 07:29 AM
Reid's Avatar
Global Moderator
That's what I figured you were asking. If that's the case I'd install ITR/CTR LMAs and valvesprings and also get your ecu chipped to make better use of your ITR cams.
Old Mar 22, 2002 | 07:37 AM
DutchITR1689's Avatar
Are you kidding? Whitout LMAs VTEC will NOT work. Those LMAs are for letting the middle "cam follower" (forgotten how it's called) following the middle cam!!!!
Old Mar 22, 2002 | 07:38 AM
h46it's Avatar
Thank you Reid.
Rolow don't worry about butting in on the thread...you wanted to know what LMA's are too...its cool man...
Old Mar 22, 2002 | 07:39 AM
Reid's Avatar
Global Moderator
Default Re: Lost Motion Assembly... (EuroITR1689)
He means ITR/CTR LMAs, not LMAs in general. All VTEC heads have VTEC LMAs, which will work with all VTEC cams. The superior LMAs are the ITR/CTR versions though.
Old Mar 22, 2002 | 07:43 AM
Ahhh... OK. Well I think it's better to have them because the ITR VTEC cam has more lift so it's better to have a stiffer LMA....
pRoJeCt TeG J SPEC
Apr 17, 2005 09:13 PM
Turbo E
Jul 9, 2004 03:12 PM
CRXEE8
20
Dec 6, 2003 11:29 AM
gamakichi77
Sep 22, 2003 09:40 PM
teger
Apr 12, 2002 03:46 PM
