ecu codes
Old Jan 20, 2006 | 09:34 AM
crxmadness's Avatar
Default ecu codes
i have an 89 crx with a obd0 b16
after the car warms up if the rpm's get below 3k the check engine light comes on
if i turn the car off and then cut it back on the light goes out but always comes back on. while the car is running the ecu shows: two long flashes in a row followed by 3 short flashes in a row. i replaced the map sensor but it still does the same thing.
Old Jan 20, 2006 | 10:19 AM
hatchinprogress's Avatar
Default Re: ecu codes (crxmadness)
well it says code 23 is your knock sensor....i hope this will help ya: https://honda-tech.com/zerothread?id=468260
Darth CRX
Apr 29, 2014 07:33 AM
crxmadness
Sep 21, 2006 12:43 PM
tpod
17
Mar 1, 2006 12:41 PM
teler86
Nov 30, 2004 12:08 PM
stockintegra
Mar 27, 2004 02:13 PM
