airbag light fix with resistor help
Old Jan 20, 2006 | 08:25 AM
949's Avatar
949
Default airbag light fix with resistor help
does anyone know how to fix the airbag light on a civic 04?
just need to know the diy fix with the resistor. replaced with recaro seats so i dont have the airbag plug anymore. need help asap
thanks
Old Jan 20, 2006 | 08:29 AM
suspendedHatch's Avatar
Default Re: airbag light fix with resistor help (949)
Just break the LED off the cluster.
Old Jan 20, 2006 | 08:55 AM
nighttrain33's Avatar
Default Re: airbag light fix with resistor help (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Just break the LED off the cluster.</TD></TR></TABLE>
You're from Cali. You should know that will get you busted by a state smog ref. I don't know where the T.S. is from, but either ignore the light, or the EP3 forum may be of more help since it is the newer Civic forum. I honestly don't know that much about the newer Civic electricals.
-Shane
Old Jan 20, 2006 | 09:09 AM
949's Avatar
949
do you know which ep forum is the best to try. im running out of time. what the www. ?
Old Jan 20, 2006 | 10:53 AM
Default Re: (949)
Go to the main H-T page and find the EP3 forum. Simple as that! Good luck.
-Shane
Old Jan 22, 2006 | 08:08 AM
Default Re: airbag light fix with resistor help (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You're from Cali. You should know that will get you busted by a state smog ref. I don't know where the T.S. is from, but either ignore the light, or the EP3 forum may be of more help since it is the newer Civic forum. I honestly don't know that much about the newer Civic electricals.
-Shane</TD></TR></TABLE>
Actually I just passed smog and the smog tech liked my aftermarket steering wheel. They don't do a safety inspection during a smog check. State smog ref?! Why the hell would I go to see him? In fact, I have a JDM ZC motor, two different smog places passed it on the visual.
Old Jan 22, 2006 | 09:02 AM
ABK's Avatar
ABK
Just ohm out the air bag in the seat and use the same resistor. Make sure you stand right in front of the air bag, because otherwise you won't get a good enough reading.
LMAO
Just J/K don't do this, unless you really want to get knocked the F uck out.
Old Jan 22, 2006 | 01:19 PM
Actually I just passed smog and the smog tech liked my aftermarket steering wheel. They don't do a safety inspection during a smog check. State smog ref?! Why the hell would I go to see him? In fact, I have a JDM ZC motor, two different smog places passed it on the visual.</TD></TR></TABLE>
From my understanding of past threads, when you go for inspections, they check to make sure you are throwing any codes or have any lights. I have also had many people on here tell me that they will fail you for actually taking the bulb out for the CEL as well as the SRS light. Since I am from MI, I don't have to worry about it.
-Shane
solider-boi
Honda Civic (2001 - 2005)
12
Jul 26, 2009 11:57 PM
92_EGhatch
20
Jul 23, 2008 12:26 AM
racereaper7
Oct 20, 2006 07:27 AM
JRizEJ6
Nov 23, 2005 06:40 PM
EKtypeRhaTcH
Dec 2, 2003 11:27 PM
