vss question about the integra cluster swap
i have a 1990 crx with an auto.. yea yea i know.. anyways, i have a 97 teg guage cluster and the wiring. all i need is the vss. what i need to know is do i need one from an auto civic, and when i do my swap to man trans with b18, can u reuse the vss and just change out the part that goes into the tranny?
thanks
mike
thanks
mike
Not to be rude, but if you use the search feature, you will probably find the answer faster. That is probably why no one has replied. It has been covered tons of times.
i have the write-up done about the swap from this site, but there was no mention on if you had an auto and wanted to swap to a man later. the swap was done in a man. i just want to know if i can get around buying two vss. i know the part with th gear is cheaper than the part with the electronics..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictlyimport »</TD></TR><TR><TD CLASS="quote">Not to be rude, but if you use the search feature, you will probably find the answer faster. That is probably why no one has replied. It has been covered tons of times.</TD></TR></TABLE>
haha do you realize that you posted this 12 minutes after he asked the question, ha no one had time to reply yet
gsxr1k05
Jan 21, 2006 04:08 AM
