ecu code problems
Old Jan 19, 2006 | 11:39 PM
Intellect's Avatar
Default ecu code problems
i just got a 88 hatchy and it was sittin in one spot for a while. when i go to start it it'll start but wont hold an idle. its throwin codes 10 and 14. if anyyone has any suggestions on what the prooblem might be just let me know.
Old Jan 20, 2006 | 01:14 AM
JDMfrontedLS's Avatar
Default Re: ecu code problems (Intellect)
well i have codes too man. but 10 is intake air temp. and 14 is electronic air control. if that helps any...
Old Feb 3, 2006 | 10:27 AM
eg_gsr11's Avatar
i had the same problem. the thing is if you did a swap then most likely you swiched the two plugs to their respective components. the plugs are exactly the same.
code 10-intake temp. sensor located behind the injectors, in the middle of the intake maifold on top of the runners cant miss it.
code 14-idle air control vlave located on the back of your intake manifold. the plug is on the bottom right.
once you do this, then unplug the negative of you battery to reset the ecu. wait 10 min. then fire her up. i hope this helps.
Old Feb 3, 2006 | 12:10 PM
Mach69's Avatar
Default Re: ecu code problems (eg_gsr11)
Use this: https://honda-tech.com/zerothread?id=468260
Those codes are the cause of your idle problem.
ES1_TopGun
Honda Civic (2001 - 2005)
11
Jun 13, 2016 06:26 PM
nitro911
Aug 18, 2011 01:31 AM
IHEARTMYHONDA91
13
Feb 20, 2008 09:20 PM
TK715
Sep 23, 2006 06:01 PM
beedoublejay
Aug 21, 2005 03:28 PM
