Civic Cooling and heating problems
Old Jan 19, 2006 | 07:58 PM
PureEF8's Avatar
Default Civic Cooling and heating problems
I got 2 friends who have the same exact cooling problems. Everytime they drive there car and there at a stop light the tempature light raise up to almost red. And then when they start moving again to cools down again. I was thinking it was the thermostat. But I am not quite sure can someone help me out?!!!!!?!?!
Old Jan 19, 2006 | 08:01 PM
Sir_Wallace's Avatar
Default Re: Civic Cooling and heating problems (PureEF8)
Make sure your cooling fan is coming on. If not that would explain why the temp goes up when the car is still.
Old Jan 19, 2006 | 08:07 PM
Cute EK's Avatar
Default Re: Civic Cooling and heating problems (Sir_Wallace)
Or you could change the coolant, that might help.
Old Jan 19, 2006 | 09:14 PM
riceburnerryan's Avatar
yeah completely flush the coolant, and then burp the system to make sure there is enough coolant in the radiator
Old Jan 19, 2006 | 09:19 PM
BoostedEMone's Avatar
Default Re: (riceburnerryan)
try your fan..if possible hook the fan up to a switch to where its constantly on and see if that helps the heating problem...
Old Jan 19, 2006 | 09:28 PM
99CivicSiBrian's Avatar
B A N N E D
Default Re: (BoostedEMone)
edit*
I asked a dumb question
Modified by 99CivicSiBrian at 7:48 AM 1/20/2006
Old Jan 20, 2006 | 06:43 AM
old man neri's Avatar
Thermostats ususually stick open. If it was that it would be cold while driving and at operation temp when idling. Your fan not coming on is the likely culprit. When idling it is suppose to provide airflow through your rad. When driving your speed does that automatically and your fan is not needed. That's why you are overheating at idle and at operation temp while driving.
Old Jan 20, 2006 | 05:56 PM
swapsshonda's Avatar
Sounds like a clogged radiator.Also check out the coolant fan fuse.
Old Jan 20, 2006 | 06:28 PM
DAcraze's Avatar
Default Re: Civic Cooling and heating problems (swapsshonda)
flush your coolant, replace your thermostat, check radiator, and fan, and put in new coolant.
dhonda00
Jun 11, 2013 04:14 PM
vlude99
Jul 30, 2009 05:58 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
dawalude
Jul 23, 2004 11:41 PM
shadowdawn
Oct 7, 2003 01:04 PM
