motors swap
Old Jan 19, 2006 | 07:52 PM
sluger17's Avatar
Default motors swap
I was wonderin if a D16Y8 will fit in a 1990 honda civic hatchback with no problems. thanks for the help.
Old Jan 19, 2006 | 09:01 PM
Mach69's Avatar
Default Re: motors swap (sluger17)
It will fit without problems. You can even reuse the stock mounts. I would convert to obd2 and run the engine the way it is suppose to be run. I believe a p2p ecu is the one you should use.
Search and you shall receive. Plenty of threads about this.
Old Jan 19, 2006 | 09:05 PM
bks84's Avatar
Loved
Yes, the y8 is a direct swap. electronically, you can run it with the PM6, but wont have VTEC unless you have a RPM activated switch (which is gay-hetto)
As Mach69 said, you can use the old mounts, trans, axles all that ****.
If you decide to stick w/the PM6 method, have it chipped to run TurboEdit and you can use the PM6 to activate VTEC, only w/TurboEdit though.
Old Jan 19, 2006 | 09:08 PM
crxnj's Avatar
Default Re: (4sd4dr)
If I was going to do this I would get a 90-91 pr4 or pm6 and chip it with d16y8 fuel maps and timing maps and run the turboedit one wire vtec..And get a 88-91 hf/si dizzy to keep it obd0..
^^ That guy beat me to it..
ef9wannabe
Dec 4, 2008 04:13 PM
See Are Ex
29
Jun 25, 2006 01:03 PM
gnar kill
Nov 15, 2004 06:35 PM
j'sCRX
Jun 16, 2004 11:31 AM
Si_Power
14
Jan 20, 2003 05:41 PM
