What would make..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">what would make the fuel pump just click everytime i would try to pump gas?</TD></TR></TABLE>
are you saying everytime you go the the gas station to fill up your fuel pump goes on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">no, when i try to pump gas, the pumper click as if the tank was full</TD></TR></TABLE>Push the nozzle farther into the tank's throat. You're not sealing it against the mouth part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">maybe you just suck at pumping gas?
lol
Full serve?
lol
Full serve?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">maybe you just suck at pumping gas?</TD></TR></TABLE>
or maybe theres something wrong? can't suck at pumping gas at every station now. happen after my swap
or maybe theres something wrong? can't suck at pumping gas at every station now. happen after my swap</TD></TR></TABLE>
Did you mess with any of the components of the gas tank during your swap? Accidentally plug a vent or something?
There was a guy on here a few months back with the same problem. He'd get in a gallon or so and it would click off.
Try getting some plastic tubing that you use for like fish tank air lines and put just a bit of it into the opening for the pump nozzle. Then put the nozzle in and try to slowly pump gas. That should help relieve some of the pressure while you are filling up.
Sounds like the pressure relief hole/valve is clogged up, which causes pressure to stay high in the tank, which causes the nozzle to cut off before you can get gas into the tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">Did you mess with any of the components of the gas tank during your swap? Accidentally plug a vent or something?</TD></TR></TABLE>
took off the fuel line coming off of the fuel rail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero »</TD></TR><TR><TD CLASS="quote">Try getting some plastic tubing that you use for like fish tank air lines and put just a bit of it into the opening for the pump nozzle. Then put the nozzle in and try to slowly pump gas. That should help relieve some of the pressure while you are filling up.</TD></TR></TABLE>
i stick that in the opening and to the side of the pump nozzle correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">i stick that in the opening and to the side of the pump nozzle correct?</TD></TR></TABLE>
Yes. I've never had the problem, but I think it should relieve at least some pressure if your vent is blocked by something else. That should allow you to at least get a little bit of gas in the car.
*WARNING* MAKE SURE YOU GROUND ANYTHING THAT YOU PUT INTO THE GAS TANK! IF IT HAS ANY KIND OF STATIC CHARGE IT COULD IGNITE THE GASOLINE. *WARNING*
