1989 CRX Si?
Old Jan 19, 2006 | 02:14 PM
wood's Avatar
Default 1989 CRX Si?
How can I tell if my son's car is REALLY anSI? I have tried to search, but can't really find the answer. Can I tell by the VIN or rather what will tell me in the VIN. My shop manual doesn't provide this information, or I have overlooked it. Any input is appreciated.
Old Jan 19, 2006 | 02:18 PM
31flavorscivic's Avatar
Default Re: 1989 CRX Si? (wood)
Sunroof would give it away. Only SI hatchbacks had sunroofs. There is some way to tell by the VIN but the method escapes me as of now.
crxnj's Avatar
Sunroof
MPFI 16 valve D16a6 motor
Nice seats (different from the dx/hf)
Should have some tear drop alloy wheels
6500rpm redline on the gauge cluster
Should have an SI badge on the back( but any idot can buy one and put it on)
Should have a small lip on the front bumper(but could be off)
The door panels should have "CRX" engraved in them.
Also what color is it?
To be %100 sure run the vin number through carfax,,
Old Jan 19, 2006 | 02:19 PM
cr-rex88's Avatar
for starters does it have a moonroof? only SI's came with them and check the engine code if it says d16 its an SI if it says d15 it is ether a dx of an hf.
Old Jan 19, 2006 | 02:20 PM
SHG_Beans's Avatar
look at all the options it's got. sunroof? si badge? d16a6? A/C? wheels? seats? tachometer and dashboard?
Old Jan 19, 2006 | 02:46 PM
wood's Avatar
Default Re: 1989 CRX Si? (Mr.speaker)
Must be an Si, Has sunroof, 6500 redline, nice seats, but door panels are JDM with power windows and folding mirrors. Would you happen to have a picture of the front bumper? You see the car was wrecked at some point and I want to make sure it has the right bumper. I know, not a big deal to some, but it is to me. I know it doesn't have the front lip you mentioned.
Old Jan 19, 2006 | 02:47 PM
wood's Avatar
Color is black
Old Jan 19, 2006 | 02:54 PM
crxnj's Avatar
See the little lip,,
Old Jan 19, 2006 | 02:58 PM
Speed--Freak's Avatar
If your vin starts with this:
Si= JHMED936
DX- JHMED835
HF=JHMED836
wood's Avatar
Any idea where i might find a detailed picture of the front bumper for this car? It has no lip, but I can make one from an Integra work with a little modification. Thanks for your help!
Just got second picture, that helps a lot! seems like everything outside is correct- except for the lip. Iguess that will be my next small project. Thanks again to ALL!
Old Jan 19, 2006 | 03:01 PM
crxnj's Avatar
http://www.hondaautomotivepart...UMPER
Old Jan 19, 2006 | 04:29 PM
Pooby88's Avatar
I've got an '88 Si and it has no front lip like that picture. It is all original. Maybe the lip was a change for 90-91?
Old Jan 19, 2006 | 05:06 PM
KansasKev's Avatar
The title might say if it is an si.
Old Jan 19, 2006 | 08:05 PM
crxnj's Avatar
Default Re: (KansasKev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooby88 &raquo;</TD></TR><TR><TD CLASS="quote">I've got an '88 Si and it has no front lip like that picture. It is all original. Maybe the lip was a change for 90-91?</TD></TR></TABLE>
All the si models come with lips..Sometimes people steel them,or they fall off..Or they get into an accident and replace the front bumper and never install the lip..
Old Jan 19, 2006 | 08:51 PM
FOMULA91's Avatar
Default Re: (Mr.speaker)
http://www.carfax.com/
and type the VIN# it should tell you the model.
Old Jan 19, 2006 | 09:44 PM
downest's Avatar
Default Re: (FOMULA91)
The 90-91 lips have cutouts for the foglights, they look a little different. If you have the roof and motor, chances are it's an Si. Also the glove box will have felt lining.
Dulluthkid_19
12
Sep 25, 2007 11:32 AM
CRXSiA1
15
Nov 5, 2004 02:07 PM
southtexrex
Nov 13, 2003 12:44 PM
outlaw_78ca
26
Aug 10, 2002 02:33 PM
sappsycho
Jun 20, 2002 05:05 PM
