sensor ?
Old Jan 19, 2006 | 12:31 PM
dasistheone's Avatar
Default sensor ?
what sensor is this and.. wat does it do beacause i broke it
http://[img]https://img353.imageshac....jpg[/img]
Old Jan 19, 2006 | 12:42 PM
Default Re: sensor ? (dasistheone)
bump
Old Jan 19, 2006 | 12:44 PM
Redline96LX's Avatar
* B A N N E D *
you have a MSD ignition and a supercharger and you dont know what a sensor is?
based on location, I'd say ECT, engine coolant temperature sensor. Youre gonna want that, cause even tho coolant flow uses a mechanical spring thermostat, that tells the ECU when to turn on the fan, so don't sit in traffic, if ya NEED to drive to a junkyard, take the long way and don't sit in traffic.
Old Jan 19, 2006 | 12:51 PM
saywhat's Avatar
Default Re: sensor ? (Redline96LX)
agreed, that is the coolant temp sensor, your car will run rich if it thinks that the engine is cold, so I would get that replaced or if you are up to the challenge replace it yourself, otherwise it might fu(k up the SC.
Old Jan 19, 2006 | 01:05 PM
Default Re: sensor ? (saywhat)
i just change my clutch/ flywheel In the process of puttin back in the tranny i broke the sensor. It also has trouble starting. When it warm( not the outside temp) it starts fine but when its cold it mad hard to start it. would this sensor have ne thing to do with this
Old Jan 19, 2006 | 01:10 PM
saywhat's Avatar
it is possible, but if your car is low on gas it will give you some trouble too.
Old Jan 20, 2006 | 10:54 PM
civteck84's Avatar
um yeah its an important sensor, unless overheating isnt important to you.. glad to see you bought a supercharger instead of altezzas tho.
mario456
Apr 6, 2013 10:03 PM
busyychild
May 6, 2008 11:09 AM
ahloung
Mar 15, 2006 11:59 AM
90LSpimpin
Nov 1, 2004 08:37 PM
