TPS and O2 Sensor!!
Old Jan 19, 2006 | 11:48 AM
matty413's Avatar
Default TPS and O2 Sensor!!
Hey I checked my ECU codes and it read that I still had the TPS problem even though I just replaced the whole throttle body and the idle still jumps up and down. Can someone help me figure out if its the wiring or do I just need to reset m ECU. Also it says my 02 Sensor is the other code. Dos that mean that I need to get another 02 sensor? Also one more thing, I had a code 19 which is like Automatic Transmission valve or something like that. What the hell is that??
Old Jan 19, 2006 | 12:09 PM
dfn_doe's Avatar
Default Re: TPS and O2 Sensor!! (matty413)
disconnect your ecu for a few minutes to clear the codes... go for a short drive and get it up to temp and see if it is throwing codes still....
RiTtEk401
Oct 4, 2011 02:52 AM
skaternak
Jul 20, 2008 10:50 AM
PWRDbyHseries
Feb 22, 2006 04:53 PM
undertheradar
Dec 4, 2004 08:03 AM
