H4/9003/9004 High temp(HID also)headlight wiring harness Civic/Toyota/Etc.
This is a perfectly good working wiring harness with dual high amp relays and H4/9003/9004 connections. This adds a full hard wired connection to your battery and large guage wiring that bypasses (uses your current for signal) weak OEM harness and prevents overheating of OEM harness which can cause fires, shorts and meltdowns of the OEM harness. This way you can run those fancy xenon and HID setups without worrying about your current setup failing. Retails for $50, used for one year in my Civic, switched to a different headlight setup so I can no longer use this setup on my car. Works like new. Asking $25 shipped.
What is it?
Is it supposed to help you run xenon hid's safely?
if so, hit me up, pm me.
i need pics also.
money talks!
i need pics also.
money talks!
Yes thats what its for, to make it so you can run XENON HIDS safley, or any higher wattage bulbs. I was using it to run my 4 bulb Civic DENJI headlight conversion...now I have no use for it because I changed my front again and it came with a harness made for the lights that came with it. I'll send you pics no problem.
.hawaii
Oct 6, 2011 09:29 AM
bz_kurb
Honda Civic (2001 - 2005)
Aug 29, 2008 06:20 PM
