Honda S2000 Honda S2000
to the People running "springs." What shocks are u running, or if you are running them?
Old Jan 19, 2006 | 09:12 AM
- BSeRiouS -'s Avatar
Default to the People running "springs." What shocks are u running, or if you are running them?
whuttup fellaz,
juss as I stated above, i was juss wondering but for the people who are running juss the "springs" itself and not full Coilovers, what shocks/struts are u running? I've seen a couple of people run juss the spring itself without any aftermarket shocks. If you are running some, what's your combo? I wish i can go full Coil but no di nero lemme know fellz, thanx
Old Jan 19, 2006 | 09:21 AM
papa5murf's Avatar
Default Re: to the People running "springs." What shocks are u running, or if you are running them? (O BSeR
tein flex... will be upgraded to tein rs... in a couple months
Old Jan 19, 2006 | 10:14 AM
Francesco's Avatar
i have zeal function b6...8kg all the way around...
i might upgrade to the s8's, but i really like my set up now...
Old Jan 19, 2006 | 12:52 PM
MAD ITR 55's Avatar
I have the Espelir springs on stock shocks.
Old Jan 19, 2006 | 02:01 PM
Chesus-s2k's Avatar
hey papa does those tein flex ride good and how low u got it drop
Old Jan 19, 2006 | 06:51 PM
04RioS2k's Avatar
eibach/koni, seems to be made for each other, perfect ride after I make my adjustments....
Old Jan 19, 2006 | 08:19 PM
Moemers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD ITR 55 &raquo;</TD></TR><TR><TD CLASS="quote">I have the Espelir springs on stock shocks.</TD></TR></TABLE>
x2
Old Jan 20, 2006 | 06:31 AM
devnull's Avatar
D2 coil-overs. I like them alot. 10k fronts and 12k rears. Set at 19 and 21. A little stiff but it helps with bump steer.
Old Jan 20, 2006 | 06:39 AM
papa5murf's Avatar
Default Re: (Chesus-s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chesus-s2k &raquo;</TD></TR><TR><TD CLASS="quote">hey papa does those tein flex ride good and how low u got it drop</TD></TR></TABLE>
the ride is great on the street.... no complaints there.....
my only complaints..
1. wish the spring rates were the same... they are 10f/12r.. but i wish they were 10f/10r or 12f/12r..
2. the edfc is a great tool... but i hardly ever use it anymore... but it makes fine tuning, and dialing in your suspension so much easier....
3. i plan on tracking the car a lot this year.. and these coilovers are not cut out to be good on the track...
and the car is slammed. i can't find a picture.. i'll post it when i get home..
Old Jan 21, 2006 | 08:01 AM
papa5murf's Avatar
Default Re: (papa5murf)
Old Jan 21, 2006 | 11:12 AM
B18_Turbo's Avatar
Thats pretty clean papa5murt. Hows the camber wear on your tires??
Old Jan 21, 2006 | 01:18 PM
Newkdog's Avatar
I miss Andrea.
where in ffx you at smurf?
Old Jan 21, 2006 | 03:41 PM
S2K K1DD's Avatar
Default Re: (badboypolar2)
hey badboy how do you like the D2 coilovers my boy is proll going to get them and wants to know how they ride and feel havent seen to many people messing with them but hes been told there are real real nice coilever PM with your responce if you want
Old Jan 21, 2006 | 04:38 PM
papa5murf's Avatar
Default Re: (B18_Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18_Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Thats pretty clean papa5murt. Hows the camber wear on your tires??</TD></TR></TABLE>
rather even.. .... little more wear on the inside but not much.. it's all about getting the proper alignment done with proper toe/camber combo... i'm running -1 up front and -2.3 rear...
Old Jan 21, 2006 | 04:39 PM
papa5murf's Avatar
Default Re: (Newk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newk &raquo;</TD></TR><TR><TD CLASS="quote">where in ffx you at smurf?</TD></TR></TABLE>
near GMU
Old Jan 22, 2006 | 09:07 AM
Yosshaa's Avatar
Old Jan 22, 2006 | 05:25 PM
crexer's Avatar
how long do the stock s2k shocks hold up with lowering springs under normal driving conditions?
Modified by crexer at 9:35 PM 1/22/2006
Old Jan 22, 2006 | 05:32 PM
silentdancer's Avatar
depends on the road conditions
Old Jan 22, 2006 | 07:06 PM
xxjdmmcdaddyxx's Avatar
Thats a SWEET Ride
poland accord
Oct 14, 2008 01:28 PM
dc5 paoer
Jan 7, 2006 08:38 PM
HYPEBEAST!
Suspension & Brakes
Apr 10, 2005 12:34 PM
305JDM
Suspension & Brakes
Mar 29, 2005 06:31 PM
