Clicking noise in doors
Old Jan 19, 2006 | 09:02 AM
MeanD's Avatar
Default Clicking noise in doors
i have a 91 civic dx and the seatbelts are in the door. when i hook up my battery cable the doors click. is this normal? i have a drain on my battery and i am trying to figure out what is causing this. any help is appreciated
Old Jan 19, 2006 | 09:06 AM
crxhf19's Avatar
Default Re: Clicking noise in doors (MeanD)
bump
Old Jan 19, 2006 | 09:32 AM
crxhf19's Avatar
Default Re: Clicking noise in doors (crxhf19)
bump please help
Old Jan 19, 2006 | 10:39 AM
fireant's Avatar
I'm not aware of any electronics inside the door other than the speaker wires.
Old Jan 19, 2006 | 10:49 AM
crxhf19's Avatar
Default Re: Clicking noise in doors (fireant)
yea there is 3 plugs that go to the side of the seat belt brackets. and they click when i hook up the battery. i just need to know if that is normal or not
Old Jan 19, 2006 | 11:11 AM
crx_88_si's Avatar
i dont think non-stop clicking coming from inside the door is normal at all.
pull off the door skin, maybe some1 installed something in there.
Old Jan 19, 2006 | 11:14 AM
crxhf19's Avatar
Default Re: (crx_88_si)
it is not non stop, only when i attach or remove my positive lead on the battery. i have removed the panels, it is three plugs like i stated eariler, and the plugs go to boxes on the side of the seat belt rolls
Old Jan 19, 2006 | 11:20 AM
SD_Lurker's Avatar
HT White Ops
Default Re: (crxhf19)
is your car on when you plug in the battery?? only thing I can think of is that your speakers are poping when they get power or that you have power locks and when you hook up the battery they flicker. If you dont have power locks than eliminate that. but possibly your speakers poping.
Old Jan 19, 2006 | 11:34 AM
crxhf19's Avatar
Default Re: (nicks_jdmstyle_ef9)
it is not speakers or power locks, it is boxes that are on the side of the seat belt rolls, they have little arms in ther that move when i touch the positive power cable to the battery and go back when i disconnect the battery, no the car is not on. to clearify, all i want to know is it normal for the seat belt "arm thingy" to move when i put power to the car and if not then what do you guys think it could be?
Old Jan 19, 2006 | 12:12 PM
crxhf19's Avatar
biggidy bump
Old Jan 19, 2006 | 12:19 PM
SD_Lurker's Avatar
HT White Ops
I dont know but maybe later when I have time I can try it on my car to see if it also does it. Other than that I have no idea what it could be.
Old Jan 19, 2006 | 01:04 PM
Tyson's Avatar
its normal. its part of the whole passive restraint system which is why they put the seat belts in the doors as well. i noticed it too when i had a battery disconnect switch mounted in the cabin.
jdm_rb20
14
Mar 30, 2013 06:08 PM
domo-ef
Jul 7, 2010 07:12 PM
miggs70
Jan 4, 2008 01:06 PM
wood 1
Jul 7, 2007 03:21 AM
rleonekc
May 11, 2006 04:52 AM
