RI: Bunch of stuff fs...stock g2/g3 parts, turbo stuff...
Hey guys, whats up? I have a bunch of stuff im looking to sell for money toward my project as my goals have changed. I figured Id start on here because most of you guys are relatively local to me and Id rather sell stuff in person so all are happy and it saves on the time and money for shipping. I have pics of most of the stuff also. I havent listed prices but I have some in mind, just make an offer and well take it from there. All are USED unless otherwise noted. There may be more items added in time. My email is xxxmikenicexxx@hotmail.com, email me with any offers/questions. Well heres the list, with aftermarket parts first then stock:
G3 GSR Side Engine Mount
G3 GSR Intake Manifold (Stock)
Black Widow Side Skirts for DA - (May Not Be Very Usable)
Combat Front Bumper for DA
10 Disk Sony CD Changer W/ Control
G3 GSR Engine-Side Wiring Harness
Eagle H-Beam Rods for GSR
Eagle H-Beam Rods for LS
JE Low Comp Pistons for LS (May or may not be usable)
Arias Low Comp Pistons for GSR (May or may not be usable)
Arias 81.5mm Piston Ring Set (File-To-Fit) *NEW*
GSR MSD Distributor Cap *NEW*
High Flow Cat *NEW*
Hallman MBC *NEW*
Super 60 Turbo *NEW*
Super 60 Turbo Inlet Flange custom from 42nd Draft Designs *NEW*
JRC Intercooler 6" *NEW*
DSM 450cc Injectors (Freshly Cleaned and Flowtested)
Custom B-Series Manifold Parts Kit I Pieced Together *NEW*
1990 LS - Interior Pieces Listed Are Graphite Black
G2 Parts(43):
AC Evaporator
Bumper + Support
Center Console Ashtray + Lighter Piece
Coil
*Combat Rear Bumper - Fiberglass
*Combo Light + Washer Switch
Compressor - AC
Compressor Bracket
Coolant Overflow Reservoir
Cruise Control System
*ECU
*Exhaust Downpipe
*Exhaust (Minus Muffler)
*Front Crossmember (One that runs Front to Back)
Front Calipers
Front Mudflaps
Glovebox
Hatch + Gas Release
*Hatch
Inside Fuse Cover
Inside Handles - Broken Lock
Instrument Cluster Bezel
Intermediate Shaft
Jack
Map Sensor
Oil Pickup
Original Owners Manual
Power Steering Fluid Reservoir
Power Steering Pump
Privacy Cover
Radius Rod
Rear Mount Brace
Shift Linkage
Shifter Dust Seal
Shifter ****
Shifter
Stock Radio
*Sunroof Assembly
Upper Control Arm
Wind Deflector
Wiper Motor (Front + Rear)
G3 Parts from a 1995 LS(6):
Exhaust
Exhaust Manifold + Downpipe
Front Left Shock Assembly - Broken Damper Fork Bolt
Fuel Rail
Intake Manifold
Taillights
High Flow Cat *NEW*
Hallman MBC *NEW*
G2 Parts(43):
AC Evaporator
Bumper + Support
Coil
Compressor - AC
Compressor Bracket
*ECU
*Exhaust Downpipe
Front Calipers
Front Mudflaps
Glovebox
Hatch + Gas Release
*Hatch
Inside Fuse Cover
Intermediate Shaft
Jack
Map Sensor
Oil Pickup
Power Steering Pump
Privacy Cover
Radius Rod
Rear Mount Brace
Shift Linkage
Shifter Dust Seal
Shifter ****
Shifter
Stock Radio
*Sunroof Assembly
Upper Control Arm
Wind Deflector
Exhaust
Fuel Rail
Intake Manifold
Taillights
can you email me specs on the super60 turbos and shipping to austin tx
email me at miguelittoangel@yahoo.com
im'd u too
im'd u too
b20turbojason
Texas -OK -LA (Sales)
Feb 13, 2009 02:50 PM
moneytwenty
Mar 10, 2007 06:50 PM
honhatchisbak
Feb 13, 2005 05:02 PM
