cable and hyrdo tranny Q
Old Jan 18, 2006 | 09:10 PM
civicguy81's Avatar
Default cable and hyrdo tranny Q
does the cable tranny from a 92 teg need a slave cylinder and a release fork boot? Im slappin a 92 cable tranny on my 94 "hydro tranny needed" engine but I just figured to get the cable conversion for it...so do I need a slave cylinder and a release fork boot?
thanks
Stu
Old Jan 18, 2006 | 09:22 PM
Luserkid's Avatar
Default Re: cable and hyrdo tranny Q (civicguy81)
Cable transmissions dont use Master cylinders or slave cylinders, there run off a cable (hints the name) To run it in you hydro car you need a conversion kit.
Old Jan 18, 2006 | 09:38 PM
civicguy81's Avatar
so what r these cables and hoses for?
http://memimage.cardomain.net/...l.jpg
Thanks
Stu
Old Jan 18, 2006 | 10:46 PM
AnDThEnWuT's Avatar
thats your vss. cable trannys run cable vss. hydro trannys run electrical vss.
Old Jan 19, 2006 | 11:00 AM
delusionracer's Avatar
its not even worth it. trade the cable tranny and some money and get a hydro. no need to downgrade.
Old Jan 19, 2006 | 04:48 PM
civicguy81's Avatar
Default Re: cable and hyrdo tranny Q (AnDThEnWuT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnDThEnWuT &raquo;</TD></TR><TR><TD CLASS="quote">thats your vss. cable trannys run cable vss. hydro trannys run electrical vss.</TD></TR></TABLE>
so do I need anything to convert that also?
and its not really downgrading...easier to find cable trannies then hydro one so if one screws up then easy replacement...but ya downgrading cauze of cable to hydro
Old Jan 20, 2006 | 04:28 PM
civicguy81's Avatar
ttt?
Old Jan 20, 2006 | 07:42 PM
transpar_nt's Avatar
If you're getting a conversion kit to run a cable tranny in your hydro car, it retains the stock slave cylinder. The rubber boot isn't used because the cable trannies use an arm (instead of the little plate the hydro ones do).
Old Jan 20, 2006 | 07:52 PM
civicguy81's Avatar
Default Re: cable and hyrdo tranny Q (transpar_nt)
I was under the impression that the cable trannies dont have slave cylinders???
Old Jan 21, 2006 | 10:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicguy81 &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression that the cable trannies dont have slave cylinders???</TD></TR></TABLE>
They don't. The conversion kit retains the use of your car's hydraulic system, and comes with hardware to mount the slave cylinder to the tranny. Then you remove the rod from the slave and put in the new one in the kit which pushes on the throwout arm to engage the clutch.
The kit also comes with a solid mount which is the perfect size and length, something you won't find in any oem mount to put a cable tranny in an eg.
MrMug3n
Aug 23, 2008 07:05 AM
Kid_SiR
26
Feb 5, 2008 10:08 PM
lilo_goki
Apr 20, 2007 11:25 PM
1TwistedEG
Mar 18, 2005 07:28 AM
AudioXtremes
Mar 19, 2003 09:24 PM
