two plugs ...where do they go?
Old Jan 18, 2006 | 07:15 PM
rewerbcrx's Avatar
Default two plugs ...where do they go?
this is on a crx hf's harness with a b18a1 in the ****
i have two plugs that i believe i know where they go but i need confirmation... hahha thanks in advanced
they are on the left (looking at the engine) they lay under the distributor, but do not run to it... and all the plugs that go into the block/ head (i can't rememeber which) underneath the distributor there are already plugged in. so the plugs are
1. flat connector with a three prongs
2. round connector with a flat one prong in it
does one go to the fan and the other go to the o2 sensor? those two plugs i never looked up and nore do i have the plug or the fan at the moment to see if it would hook right up lol
thanks
Modified by rewerbcrx at 11:28 PM 1/18/2006
Modified by rewerbcrx at 11:29 PM 1/18/2006
Old Jan 18, 2006 | 07:23 PM
rewerbcrx's Avatar
Default Re: two plugs ...where do they go? (rewerbcrx)
quick bump
Old Jan 18, 2006 | 07:32 PM
jlicrx's Avatar
does the 3 wire have a yellow, a yellow/white & a green/white? if so, that was for the EGR valve on the HF - you don't need it - what color wire on the 1 wire connector?
Old Jan 18, 2006 | 07:42 PM
rewerbcrx's Avatar
Default Re: two plugs ...where do they go? (jlicrx)
its in teh same place as the round connector with one lat prong in it .... and i don't knwo the colors my shop is 7 miles away
Old Jan 18, 2006 | 07:45 PM
rewerbcrx's Avatar
i will check tomarrow on the yellow yellow/white and green/ white to see if thats it...
could you answer the last question i posted on my thread to you ? thanks a bunch https://honda-tech.com/zerothread?id=1483935
Old Jan 18, 2006 | 09:20 PM
jdeemseerx's Avatar
i believe its the coolant temp sensor and the sending unit goin to the temp gauge
Old Jan 18, 2006 | 09:55 PM
bigcalidave's Avatar
The wires that lead forward under the dist are usually the o2 sensor, coolant temp, and the wires to the transmission.
Old Jan 18, 2006 | 11:37 PM
celestialcivic91's Avatar
hey,
post up some pics of the plugs, instead of having to explain and we can tell you right away
Mike
Old Jan 19, 2006 | 08:11 AM
rewerbcrx's Avatar
Default Re: two plugs ...where do they go? (celestialcivic91)
i will take pics tonight
Old Jan 19, 2006 | 08:36 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The flat three prong used to go to the EGR valve..
As for the other,Do you see it in this pic?
Old Jan 19, 2006 | 09:10 AM
rewerbcrx's Avatar
Default Re: two plugs ...where do they go? (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">The flat three prong used to go to the EGR valve..
i think the one on the left might be it ( the white one) but i would only be able to tell if it had only one flat prong in it...
Old Jan 19, 2006 | 09:51 AM
rewerbcrx's Avatar
bump
Old Jan 19, 2006 | 11:17 AM
88DXCRX's Avatar
The plug circled is the O2 sensor..
Single white wire with a single flat prong..
Old Jan 20, 2006 | 04:51 AM
yeah like the ^^^^ post says, if it's the white plug then it would be the O2 sensor plug which is a single prong
also around that plug should be the reverse light wires, temp sensor plug
let me know
Mike
Old Jan 20, 2006 | 04:42 PM
rewerbcrx's Avatar
these are the plugs that i have... the green and yellow wire there i am also unsure of right now... i believe it goes into the bottom front side of the tranny... i have the that plug plugged in right now (the person i got the tranny and engine from had the plug int he tranny but cut the wires)
ps. all the plugs under the distributor there are plugged in
Old Jan 20, 2006 | 05:56 PM
88DXCRX's Avatar
green and yellow go to the reverse light switch..
On the transmission..
Turns on the reverse lights when you back up..
Old Jan 20, 2006 | 06:17 PM
rewerbcrx's Avatar
so the round one is to the o2 sensor and the flat one i dont' need to worry about ?
Old Jan 21, 2006 | 12:54 AM
the round one is the O2 sensor plug and the green/yellow wires are for your reverse lights
as for the flat plug i have never seen that before...ill look into for you
Old Jan 21, 2006 | 10:19 AM
DieMaster's Avatar
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by celestialcivic91 &raquo;</TD></TR><TR><TD CLASS="quote">as for the flat plug i have never seen that before...ill look into for you</TD></TR></TABLE>
yes that was the lift sensor on the EGR. u dont need it. my DPFI sestem had it but i dont use the plug since i;m MPFI now.
round one is for the o2. i bet your getting a CEL. try pluging that in and bye bye cel
Old Jan 22, 2006 | 02:36 PM
rewerbcrx's Avatar
where does the fan hook up to then?
Old Jan 22, 2006 | 03:06 PM
Ryhound's Avatar
Bottom of the fan housing/bottom of rad.
skidmarkroyalty
May 7, 2014 07:26 PM
Brian_midwest
Mar 20, 2011 09:11 PM
egkingfl
Sep 7, 2009 04:12 AM
bojan
Feb 14, 2003 12:26 PM
