91 crx si steering rack..HELP
Old Jan 18, 2006 | 06:55 PM
efrex's Avatar
Default 91 crx si steering rack..HELP
i have a 91 crx si/b16....for a while now everytime i get on the freeway and take it over 65mph..the front of my car starts to shake.specially the steering wheel.i just got new tires.replaced the wheel bearings and hubs bout 5 months ago..i jacked up my car yesterday and noticed that the boots on the steering rack were ripped on both sides..could this be causin my car to shake? if so.do i need to replace the whole steering rack or just the boots and is it easy to do? if someone can please help.i'd appreciate it..thanks......i 4got to mention...when im on the freeway,the car sways left to right,right to left..as if the wheels wanna go in different direction
Modified by efrex at 8:19 PM 1/18/2006
Old Jan 18, 2006 | 07:01 PM
CRX Toad's Avatar
Default Re: 91 crx si steering rack..HELP (efrex)
I would get some boots on it and no you don't need to buy a new one. Search rack end bushing and you will probably get your answer. You can always rebuild your current one.
Old Jan 18, 2006 | 07:19 PM
SiRay13's Avatar
my guess is that one of your wheels isnt balanced, look around the rim and see if you can tell if a weight fell off, have a tire shop spin balance your front tires.
Old Jan 19, 2006 | 08:53 AM
efrex's Avatar
Default Re: 91 crx si steering rack..HELP (SiRay13)
thanks for the replies...anyone else??
Old Jan 19, 2006 | 09:28 AM
Tyson's Avatar
rack end bushing. or inner tie rod balljoint. or any one of your other balljoints.
those boots protect the rack. if crap gets up there, your rack and the bushing, which is plastic, and the inner balljoint will get worn quickly.
but you gotta check everything. it could be just one thing completely trashed, or a lot of little things. id even consider axles.
check the rack end bushing by turning the wheel all the way left, then get under the car and just grab the rack thats sticking out. push it up and down. if you feel any play, the bushing is toast.
then have a friend turn the wheel and put your hand on the outer tie rod balljoint. there shouldnt be any play there either.
then grab the wheel again, and with it already in the air, pull UP on it. that will help diagnose the condition of your upper and lower balljoints.
Old Jan 19, 2006 | 09:35 AM
efrex's Avatar
Default Re: 91 crx si steering rack..HELP (Tyson)
ok..ima do that..thanks alot..i really appcriate it
cantresjr
Dec 13, 2010 10:42 PM
gpdxtrm
13
Dec 28, 2007 08:10 PM
alscrx
Suspension & Brakes
Oct 1, 2007 01:56 PM
jaydm98
Sep 9, 2003 03:33 PM
