crazy irratic idle
Old Jan 18, 2006 | 05:31 PM
dystro's Avatar
Default crazy irratic idle
ok guys i need help, i just got an act clutch and fidanza flywheel installed, slave cylinder, rear main seal... i start driving home from the shop and my ******* idle is going up and down and sounding like ****, its normal idle is 700, but now its like 1100-1400, going up and down up and down... and my check engine light keeps coming on and off.. wtf is going on?
Old Jan 18, 2006 | 05:48 PM
BlueLude 94's Avatar
Default Re: crazy irratic idle (dystro)
Check you IACV and your vacum hoses.
Old Jan 19, 2006 | 10:22 AM
amckee's Avatar
Get that engine code before you jump to conclusions about the idle.
Old Jan 19, 2006 | 02:30 PM
cr@zy wheel's Avatar
Default Re: crazy irratic idle (amckee)
i have no engine codes but i still have this problem..the only thing is my check engine light is off ...
Old Jan 19, 2006 | 02:38 PM
dystro's Avatar
Default Re: crazy irratic idle (cr@zy wheel)
my check engine light comes on and off, at various times... and the surging/irratic idle isnt all the time either, its only occausionally... but my Warmed up idle is about 300 rpm higher than it should be.... either way, when the check engine light comes on again, im gonna read the codes... ill let you guys know what it says
Old Jan 19, 2006 | 09:02 PM
amckee's Avatar
You can read them anytime unless you erased them by unplugging the battery or back up fuse.
Old Jan 20, 2006 | 12:53 PM
JDMF22B's Avatar
obd1 or 2?
Old Jan 30, 2006 | 11:16 AM
dystro's Avatar
Default Re: crazy irratic idle (JDMF22B)
all is fixed, apparently one of the vacuum hoses was lose or unhooked, and my oil filter was loose too, heh.. i was leaking tons of oil.. those bastards!.. but all is well now
Old Jan 30, 2006 | 11:22 AM
hulk_22's Avatar
fast idle valve control right under the tb. plug the hole up and if it stops then replace the fivc
gtec28
May 18, 2007 07:13 AM
sky9
Jan 3, 2007 07:01 AM
bertyman
Dec 11, 2005 04:15 PM
cchev
Jan 23, 2004 04:00 PM
