clutch for 90-91 different then 88-89?
well i bought a clutch that clearly siad 90-91 but i did not care i thought it would be a easy fix. the pressure plate does not fit on my 88-89 flywheel. is all i have to do is switch to a 90 or 91 fly wheel?
switching the fly wheel well be okay as long as the engine codes are the same D-series, B-series etc. Maybe the flywheel you bought was for a d16a6 and your motor is a d15 than the si d16a6 tranny would have a bigger spline this is just an example per say but you get the idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR »</TD></TR><TR><TD CLASS="quote">i just bought the clutch wich is for a 91 or 91 and my motor is a 88</TD></TR></TABLE>
O.o
88 has a different spline count on the transmission. It has 21 splines and a 200mm surface, whereas the 89 has a 20 spline and the flywheel is 200mm. The 90-00 is 20 spline and 212mm I think (unless I got the whole 212-200 thing backwards, but it is different for those years.)
That clutch will not fit the transmission.
O.o
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic »</TD></TR><TR><TD CLASS="quote">O.o
That clutch will not fit the transmission.</TD></TR></TABLE>
i just went through this putting a 89 si tranny on my d15b
hes correct except for the 90-00 clutch is 220mm
p.s. a clutch for a 84-89 prelude Si is a 220mm clutch with 21 splines i just told them i need one for an 86 prelude si and it worked im not sure on the years but i think it was 84-89 if you go with 86 you are golden
the clutch disc fits fine on the tranny. its not the original tranny, i bought it seperate. i just cant fit the pressure plate on the flywheel. can i just change the fly wheel to a 90 or 91??????
agendadjs
Dec 8, 2007 04:56 PM
racingant
Sep 6, 2004 08:08 PM
orido 1.6
Jun 6, 2004 12:45 AM
DC2-JRSC'd
Mar 29, 2004 12:37 PM
BAZ
11
Mar 4, 2004 06:25 PM
