Info D16a6 zc
Old Jan 18, 2006 | 04:58 PM
farmboy777's Avatar
Default Info D16a6 zc
hi i need any info people have on the SOHC (non-vtec) ZC i've been told its basically the same as the D16A6, is this true.. if so can i use any parts from the D16A6 on my SOHC ZC? any info would be great thanx
Old Jan 18, 2006 | 06:36 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Info D16a6 zc (farmboy777)
Same engine exactly, only a different cam.
Old Jan 18, 2006 | 07:30 PM
ludesrv's Avatar
I thought it had high compression too? I got a SOHC ZC, and they are fun, peppy engines!
Old Jan 18, 2006 | 07:37 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">I thought it had high compression too? I got a SOHC ZC, and they are fun, peppy engines!</TD></TR></TABLE>
The sohc zc is fun, but still uses the same pistons. I have torn them apart and seen 1st hand.
kantfadedisazn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farmboy777 &raquo;</TD></TR><TR><TD CLASS="quote">hi i need any info people have on the SOHC (non-vtec) ZC i've been told its basically the same as the D16A6, is this true.. if so can i use any parts from the D16A6 on my SOHC ZC? any info would be great thanx</TD></TR></TABLE>
its similar but different, has more agressive cam 88-91 SOHC ZC longblock
120Hp 100Trq 9.1 compression (JDM) and the tranny is shortor than the si tranny its a good motor and bang for the buck
Old Jan 18, 2006 | 07:42 PM
Got_soy's Avatar
Default Re: Info D16a6 zc (kantfadedisazn)
some have oil coolers aswell
Old Jan 18, 2006 | 07:57 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">some have oil coolers aswell</TD></TR></TABLE>
Some d16a6 engines have oil coolers as well,,like the wagon and 90-91 ex civic..It's not really worth wild or anything though.
Old Jan 18, 2006 | 08:17 PM
Got_soy's Avatar
Default Re: Info D16a6 zc (Mr.speaker)
and i thought i was special
Old Jan 18, 2006 | 09:26 PM
bagpipe goatee's Avatar
oh, just to add in here, i noticed the IM layout of sensors was slightly different between my 91 sohc zc and my 89 d16a6. it also has a higher amp alternator than we got here.
Old Jan 18, 2006 | 09:30 PM
crxnj's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">oh, just to add in here, i noticed the IM layout of sensors was slightly different between my 91 sohc zc and my 89 d16a6. it also has a higher amp alternator than we got here.</TD></TR></TABLE>
Good info,,Do you know the exact amp rating on the alternator?
Old Jan 19, 2006 | 06:44 AM
no i don't, but I know it uses a belt that's a rib wider. My engine appears to have a lot of differences, though. different logo on the valve cover, off an automatic, power steering, etc. So it could just be this motor and not all of them.
Old Jan 19, 2006 | 08:13 AM
farmboy777's Avatar
Default timing
so installing a timing belt is the same as a D16A6? as well as the valve clearances thanx
Old Jan 19, 2006 | 08:26 AM
boostinaintez's Avatar
Default Re: timing (farmboy777)
sure is
revikan
Feb 28, 2008 06:51 PM
the king.
Sep 26, 2006 12:32 PM
fbapacible6
Sep 5, 2004 12:43 PM
CRneXt
39
Oct 7, 2003 02:13 PM
mikikanazawa
Aug 14, 2003 09:08 PM
