Accord H22/H23 problem
Old Jan 18, 2006 | 02:49 PM
Acrappyhatch's Avatar
Default Accord H22/F23 problem
I have searched.
i swapped a H22 into a 2001 accord that had a f23 in it.
I am almost done but stopped due to Distributor problem.
I am using the Accord harness and the plug for the distributor is different for f23 and H22.
i was wondering if anyone has done this and what they did to make this work?
i have read a few threads thru searching but done describe this problem yet.
thanks
blake
Modified by Acrappyhatch at 8:05 PM 1/26/2006
Old Jan 18, 2006 | 06:02 PM
help?
Old Jan 26, 2006 | 08:38 AM
I have a 2001 accord harness.
the plug for the distributor only has four wires.
my plug for my 0bd2 distributor has 9 wires.
some one please help me out...
Old Jan 26, 2006 | 12:29 PM
iakona's Avatar
internal vs. external coils? that would explain the additional wires.
Old Jan 26, 2006 | 05:05 PM
well this harness side plug only has 4 wires...
i guess i just need to get a H22 harness
Old Jan 27, 2006 | 12:26 PM
twobit's Avatar
Default Re: (Acrappyhatch)
How much was your H22 and how long did it take to put it in if you did it yourself? Also if you did it by shop tell me how that worked out. Once it's running keep us posted on how the performance is, I might be swappin mine instead of rebuildin the stupid tranny, so keep us all posted!
Old Feb 2, 2006 | 10:16 PM
duceducecord's Avatar
Default Re: (iakona)
if u have 9 wires on that distrubtor of urs then that is a internal coil i had the same problem, you would have to re-route the crank sensor wires to that plug converting it into OBD1 and if u have a coil plug i believe it is the yel/blk and blk wire u connect them together and the green one u leave it hanging/cut it do watever with it. this will convert ur OBD2 into OBD1 u might need to get OBD1 injectors not sure. my motor is a OBD1 into a OBD2 CD but i had to use the OBD2 CD wiring harness and all i had to do wat just connect thost two wires yel/blk and blk together then with a handy manual useing two of the wiring diagrams jus match up the CYL TDC and Crank sensor wires to that 9 plug. n if the h22 is a OBD2 then jus get a OBD2 distrubtor n plug n play otherwise happy CONNECTING! need ne thing respond
Old Feb 3, 2006 | 04:05 AM
v4lu3s's Avatar
RTFM
you have an obd1 h22. your car is obd2. thus the wiring differneces.
Old Feb 3, 2006 | 11:56 PM
Default Re: (v4lu3s)
yup either convert to OBD1 or OBD2 i went with OBD1 sense the motor was already OBD1 n had to move those wires around i'll send pictures if u want to see it
BrokeAssWhiteboy
Jan 23, 2006 07:48 PM
spettinger
May 31, 2004 05:44 PM
-Bionic-
Oct 10, 2003 12:11 PM
KTeller8
Sep 29, 2002 12:39 PM
