NGK BKR7E-11...what to gap them to?
Old Jan 18, 2006 | 02:25 PM
Junkyard2000's Avatar
Default NGK BKR7E-11...what to gap them to?
i did some research and decided to give these a shot. Supposedly they are more for turbo/nitrous apps but also recommended for higher compression motors. IM running ~11:1 b16. The current ones i have are the bkr6e's and they seem to be misfiring. The 7's came pregapped to a bout .040...should I leave em that way or is there a recommended gap?
Old Jan 18, 2006 | 04:35 PM
Driven's Avatar
Default Re: NGK BKR7E-11...what to gap them to? (Junkyard2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote">i did some research and decided to give these a shot. Supposedly they are more for turbo/nitrous apps but also recommended for higher compression motors. IM running ~11:1 b16. The current ones i have are the bkr6e's and they seem to be misfiring. The 7's came pregapped to a bout .040...should I leave em that way or is there a recommended gap?</TD></TR></TABLE>
if you do a search in the all motor forum, the have recommended specs.
IIRC, it's around 32-36
Old Jan 18, 2006 | 05:29 PM
The AntiRice's Avatar
not sure how much it matters, but there is a BKR7E-11 and there is just straight BKR7E. I run these plugs in my supercharged Si and upon checking NGK's website, there are some slight differences but I'm not sure what they work out to be. To my knowledge, the ones I've always used are just straight BKR7E without the -11, so maybe someone can shed some light. NOt many auto parts stores around here stock them either *shrug*
Old Jan 18, 2006 | 10:37 PM
Default Re: NGK BKR7E-11...what to gap them to? (The AntiRice)
im pretty sure the 11 means it comes pregapped
Old Jan 19, 2006 | 01:19 AM
NastyHabitzCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure the 11 means it comes pregapped</TD></TR></TABLE>yup the -11 just means what gap they have from NGK. i run the ungapped ones down to 28 for 15 psi
Old Jan 20, 2006 | 05:28 PM
LoneStarCRX's Avatar
-11 means 1.1 mm. Pregapped but go ahead and check them anyway.
ORANGE EF
Aug 30, 2006 03:29 PM
nastycivic101
Jun 6, 2006 08:02 PM
snowseeker
Jul 20, 2005 05:21 PM
4ghatch
Apr 30, 2005 08:56 PM
RI_TM
Mar 22, 2005 06:37 PM
