Where Is Radio Fuse Location on 94?
Old Jan 18, 2006 | 12:42 PM
ScottieA's Avatar
Default Where Is Radio Fuse Location on 94?
Old Jan 18, 2006 | 01:12 PM
specbb6's Avatar
Default Re: Where Is Radio Fuse Location on 94? (ScottieA)
Should be on the under-dash fuse box. Inside the fuse-box cover is the fuse pattern.
Old Jan 18, 2006 | 03:02 PM
94jdmcd5's Avatar
Check under the hood next to I think its next to the interior fuse it would be a 7.5 fuse.
Old Jan 18, 2006 | 03:06 PM
P_Adams's Avatar
Actually, the '94 o/m reports
Under-Hood Fuse Box
Location #10 7.5a radio/backup
Location #18 15a radio/cig lighter
P
Old Jan 18, 2006 | 03:36 PM
P_Adams's Avatar
Default Re: Where Is Radio Fuse Location on 94? (Group A)
I believe it is, they share the same Fuse Boxes.
P
Old Jan 18, 2006 | 03:38 PM
noobie's Avatar
Default Re: Where Is Radio Fuse Location on 94? (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Actually, the '94 o/m reports
Under-Hood Fuse Box
P</TD></TR></TABLE>
I beg to differ Mr P sir.........but a 94 accord stereo fuses go as follow
underhood fuse box # 36 15 amps
underhood fuse box # 39 7.5 amps
under dash fuse box # 11 10 amps
Got those form the 1994 accord ETM
Old Jan 18, 2006 | 03:44 PM
P_Adams's Avatar
Default Re: Where Is Radio Fuse Location on 94? (noobie)
ok, what's the third fuse for? 1) Radio memory, 2) Radio power 3) ?
P
Old Jan 18, 2006 | 03:57 PM
P_Adams's Avatar
You may be correct, maybe not. I grabbed a manual w/out a cover, turned out to be my '97. Let me confirm (or correct) what I said - be back
** as far as I can tell, I can't see any difference between 94-95 and 96-97 underhood boxes. Both have 24 fuse bays, 4 Master Fuses, and 4 Relays- same layout
I'm correct, '94-97 fuse boxes are interchangable
P
Modified by P_Adams at 1:18 AM 1/19/2006
Old Jan 18, 2006 | 05:44 PM
Diego Dangers.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">You may be correct, maybe not. I grabbed a manual w/out a cover, turned out to be my '97. Let me confirm (or correct) what I said - be back
P
Modified by P_Adams at 1:18 AM 1/19/2006</TD></TR></TABLE>
affirmative. there are only 2.
Old Jan 18, 2006 | 06:58 PM
P_Adams's Avatar
Default Re: Where Is Radio Fuse Location on 94? (Diego Dangers.)
Thank You, I had to stop and think for a moment.....
P
Old Jan 18, 2006 | 07:07 PM
noobie's Avatar
1 wire is for memory......... the remaning 2 , power the cig liter relay..you will get no power to stereo unless cig liter relay is energized , the fuse under dash has power at 1 side of relay , ,, underdash fuse # 36 powers the other side of relay ... if under dash fuse is blown it cannot energize the relay thus the wire from fuse # 36 will not get power at the other side of the relay and cannot power the stereo..
like i said ,i saw the diagrtam in the 94 accord Honda ETM ,,
if the underdash fuse # 11 or underhood fuse # 36 are blown stereo will not work
Old Jan 18, 2006 | 07:09 PM
noobie's Avatar
ooooooooops meant to say underhood fuse # 36 ,powers the other side of relay and not underdash fuse # 36......underdash fuse is # 11 ,,10 amps
Old Jan 18, 2006 | 09:36 PM
P_Adams's Avatar
Default Re: (Group A)
Thank you not only for the confirmation, but the "That Fixed it!!" Report as well.
I like to keep track of such things.
P
Punkfarter
Audio / Security / Video
Oct 26, 2012 04:23 PM
HondaTech101
Apr 7, 2007 06:59 AM
rcarpen22
Mar 21, 2006 07:42 AM
GumballNA
Nov 16, 2004 02:35 PM
cohasi2003
Mar 2, 2003 03:30 PM
