Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
IIM: K-Sport Coilover Sale.... New Applications... Awesome Prices!!
Old Jan 18, 2006 | 12:34 PM
ImageInMotion.com's Avatar
Default IIM: K-Sport Coilover Sale.... New Applications... Awesome Prices!!
kontrol pro damper system.
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
applications go here http://www.ksportusa.com/produ....html
slide kontrol drift damper system.
Ksport Slide Kontrol Drift Damper System provides the ultimate in suspension technology featuring its 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. The Ksport Slide Kontrol Drift Damper System has been designed to endure the extended abuse and extreme handling of drifting.
gt pro damper system.
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring its inverted monotube design, 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and braking system reducing heat transfer This design also reduces under-sprung weight, which improves handeling and responsiveness.
rally gr spec type damper system.
Ksport Rally Spec GR Type Damper System are designed specifically for gravel rally competition. It includes longer stroke, durable construction, and simultaneous compression and rebound adjustment. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
rally ar spec damper system.
Ksport Rally AR Spec Damper System is designed specifically for asphalt rally competition. It features extended stroke, heavy duty internals, and simultaneous compression and rebound adjustment. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
we will beat any avertised price
PLEASE PM, CALL OR EMAIL FOR PRICING
contact info
phone 1-866-238-1947
AIM: imageinmotion16
Modified by ImageInMotion.com at 1:44 PM 2/1/2006
Old Jan 18, 2006 | 09:49 PM
Default Re: IIM: K-Sport Coilover Sale.... New Applications... Awesome Prices!! (ImageInMotion.com)
thanks for the PM's guys
Old Jan 19, 2006 | 10:48 AM
ttt
Old Jan 21, 2006 | 11:29 PM
ttt
Old Jan 23, 2006 | 11:31 AM
ttt
Old Jan 24, 2006 | 11:40 PM
ttt
Old Jan 24, 2006 | 11:56 PM
ludeboi121's Avatar
Default Re: (ImageInMotion.com)
price on kontrol pro dampers for 97+ prelude shipped to 91803? very interested depending on the deal and how soon i can get them thanks!
Old Jan 25, 2006 | 12:27 PM
u got pm
Old Jan 26, 2006 | 10:47 PM
tttt
Old Jan 27, 2006 | 10:29 AM
ttt
Old Jan 29, 2006 | 09:18 PM
ttt
Old Feb 1, 2006 | 11:58 AM
ttt
Old Feb 3, 2006 | 09:11 AM
ttt
Old Feb 4, 2006 | 11:47 PM
ttt
Old Feb 6, 2006 | 07:44 AM
ttt
Old Feb 8, 2006 | 07:13 PM
ttt
Old Feb 9, 2006 | 12:07 PM
up
Old Feb 14, 2006 | 05:42 AM
ttt
Old Feb 16, 2006 | 05:40 AM
integlspwr2k's Avatar
Can you guys get the Version RR Damper System for 94+ Integra?
Old Feb 16, 2006 | 06:20 PM
95greenGSR's Avatar
Sent you a pm
Honda Gen
12
Nov 15, 2008 11:36 AM
JGDynasty
32
Jun 20, 2007 09:24 AM
giff74
Suspension & Brakes
Jul 27, 2005 11:54 PM
jisu009
Apr 14, 2003 10:24 AM
RTW DC2R
Oct 8, 2002 05:32 PM
