short-ram squeeky??
anyone ever install a short ram air intake in an '01 accord and have it rub that silver little pipe right under it while idleing, and makes a squeeking noise. More testing is in progress jsut need another person...
Yes, that's how mine is, and my friend's as well. I wrapped the A/C line with foam. My friend left his alone, and it started to wear a groove into his intake. Mine hasn't had any problems since I wrapped it.
i dont have a short ram, but i do have a CAI, and noticed similar problems when im sitting at a stoplight and idle for more than 20 or so seconds. It more or less rattles and squeaks in the engine, and I know its from the intake because it didn't happen before.
I took the intake off and put the foam adhesive around the ac line wrapped w electrical tape, man there is a little groove in the intake tube from the vibration, after only like a month. damn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OSIRIuS23 »</TD></TR><TR><TD CLASS="quote">I took the intake off and put the foam adhesive around the ac line wrapped w electrical tape, man there is a little groove in the intake tube from the vibration, after only like a month. damn.
foam would wear out fast.
use a clear one inch(or bigger) hose(from homedepot), cut it, wrap it around and zip tie the end.
you don't want to bust your a/c house, they are expensive to replace and they hold alot of pressure.
</TD></TR></TABLE>foam would wear out fast.
just an update so far. Well the foam is covered with electrical tape, so its not wearing out....which is good and the squeeking is gone ! I guess if it does wear out I will go with 7 heads idea, stay up!
