Is it my spark plugs that are messed up
Old Jan 18, 2006 | 11:18 AM
Uponforever20x's Avatar
Default Is it my spark plugs that are messed up
Today, when I got off work...i needed to put water in the car...but i didn't have no water to put...so i went to mc donalds...ten minutes later...
my temp gauge is goin of the charts....so i put water in the radiator...when i started to put water....5 seconds later the radiator gushes out the water and it lands on my engine and other parts....i continue putting it after cleaning it off ..and its cool...
so then i get home and i get ready for school..when i come out and turn my car on again....my engine sounds like when you remove a spark plug harness from its place...so i then i leave the engien on...and i expletive with the spark plug harness....all of them seemed to be working right....but when i took one of them off the engine did not have any affect....usually, when you remove a spark plug harness the engine sounds unbalance..like if its dying out...but when i did it to this one....nothing happened...so i'm assuming that one spark plug is messed up....can it be the injectors to...or the engine in particular...i hope i made sense and i could seriously get some tech. help..thanx...
Old Jan 18, 2006 | 11:22 AM
Pee Wee's Avatar
Default Re: Is it my spark plugs that are messed up (Uponforever20x)
could also be the dizzy. check that also
Old Jan 18, 2006 | 12:33 PM
jlicrx's Avatar
did it get some water down in the spark plug wells?
Old Jan 18, 2006 | 04:51 PM
MyEVO8u's Avatar
you may have got water done in the holes or in the dizzy just blow it out should be the problem nothin major
s7mk
Honda Civic (2006 - 2015)
14
Oct 29, 2009 03:30 PM
JoHA
Apr 6, 2006 01:53 PM
.Kevin.
Aug 25, 2005 06:46 AM
hatchback_al
15
Jul 21, 2004 02:15 AM
FitCRX
Jun 13, 2002 10:22 PM
