Installing my Spoon N1 exhaust should i change the exhaust gasket
Old Jan 18, 2006 | 11:06 AM
EG6civic's Avatar
Default Installing my Spoon N1 exhaust should i change the exhaust gasket
installing my spoon n1 exhaust this weekend...should i change the exhaust gasket with a new one from the dealership...and would the stock exhaust gasket fit just fine with the spoon exhaust...i'm just running the stock piping on it for now...any suggestions? thanks.
Old Jan 18, 2006 | 11:12 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Installing my Spoon N1 exhaust should i change the exhaust gasket (EG6civic)
If it fits and is in good condition, use it. If not, then use the new one.
Old Jan 18, 2006 | 01:30 PM
nightrider's Avatar
the dealership gasket will not work because of the difference in diameter of the spoon N1 and the oem axleback. you should be able to go to any muffler shop and have them find you a gasket that will work. since they're so cheap, you should just go buy gaskets.
edit: you can run the oem b-pipe to the spoon N1 axleback?? huh??
Old Jan 18, 2006 | 01:46 PM
B2FiNiTY's Avatar
Default Re: Installing my Spoon N1 exhaust should i change the exhaust gasket (nightrider)
Yes, the stock gasket fits fine. If yours is not damaged, just keep it.
Old Jan 18, 2006 | 01:55 PM
EG6civic's Avatar
Default Re: Installing my Spoon N1 exhaust should i change the exhaust gasket (B2FiNiTY)
thanks...i'll try the stock gasket..
Old Jan 18, 2006 | 02:05 PM
jetydosa's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">edit: you can run the oem b-pipe to the spoon N1 axleback?? huh??</TD></TR></TABLE>
Yeah.
Petah
Jan 14, 2009 11:36 AM
ITR43
Nov 23, 2004 09:07 PM
iperez
Jan 27, 2004 03:23 AM
ej0513
Oct 28, 2003 08:39 PM
mantic6t9
Jan 6, 2003 05:53 PM
