no spark or gas on my b18a1
Old Jan 18, 2006 | 09:06 AM
spooncrx91's Avatar
Default no spark or gas on my b18a1
i just finish putting a b18a1 on my 91 crx si .what do i do if gas doesnt flow to the motor and it got no spark?
Old Jan 18, 2006 | 12:27 PM
crxnj's Avatar
Default Re: no spark or gas on my b18a1 (spooncrx91)
Main Relay possibly? And recheck your wiring.
Old Jan 18, 2006 | 04:45 PM
MyEVO8u's Avatar
how do you know your not getting fuel or spark
Old Jan 18, 2006 | 07:38 PM
ludesrv's Avatar
Default Re: no spark or gas on my b18a1 (slvrcrxtuner)
It's pretty simple to tell, while cranking, take one spark plug wire out, ground it to something, hear a tick? If not, no spark. Loosen the fuel line a bit, crank the motor, gas not leaking? No gas.
Check your relay and your wiring. Sounds like you forgot to reconnect something.
Old Jan 19, 2006 | 08:05 AM
spooncrx91's Avatar
Default Re: no spark or gas on my b18a1 (ludesrv)
i recheck the wires and there all good and i did that one thing with spark plug wire and nothing happens and all the relay are good
Old Jan 19, 2006 | 08:19 AM
boostinaintez's Avatar
most likely wiring
Old Jan 19, 2006 | 09:05 AM
spooncrx91's Avatar
Default Re: no spark or gas on my b18a1 (boostinaintez)
do i need to use the ls harness or the harness form the crx?
Old Jan 19, 2006 | 12:49 PM
spooncrx91's Avatar
cuz the harness i got its a obd0 and the motor is a obd1 so wat do i do?
Old Jan 20, 2006 | 03:56 PM
MyEVO8u's Avatar
you have to use the crx harness ...it is cranking right?...check grounds and wiring its gotta be in the wiring somewhere
aaron_ex
Jan 25, 2009 05:21 PM
SOHCEK-Turbo
11
Mar 6, 2005 09:32 AM
aaronbb22
Mar 15, 2004 10:42 AM
KevronsEG
11
Mar 28, 2003 05:42 AM
blayzenazn
Mar 16, 2002 08:45 PM
