No Tach?! Common Issues with Accord Tachs would be appreciated! Thanks!
Old Jan 18, 2006 | 08:37 AM
Brain3208's Avatar
Default No Tach?! Common Issues with Accord Tachs would be appreciated! Thanks!
Well my accord is pissing me off more and more. Parked my 91 auto accord last night and i come out this morning, start the car up and wohoo! No tach! What could cause this? After the car was warmed up the Tach started working(possibly the tach wire in the Dizzy?)
Any Suggestions?
Brain
Old Jan 18, 2006 | 09:38 AM
YeuEmMaiMai's Avatar
Default Re: No Tach?! Common Issues with Accord Tachs would be appreciated! Thanks! (Brain3208)
check your ignition wiring since the tach gets it signal from there off of the distributor
Old Jan 18, 2006 | 09:53 AM
Brain3208's Avatar
Default Re: No Tach?! Common Issues with Accord Tachs would be appreciated! Thanks! (YeuEmMaiMai)
Ignition wiring? as in the actual ignition switch?
Old Jan 18, 2006 | 10:57 AM
no the engine ignition wiring your tach picks up the signal from the distributor. check the tach output from there and work your way towards the tach.
Old Jan 18, 2006 | 11:25 AM
v4lu3s's Avatar
RTFM
most likely a loose wire on the ICM inside the distributor.
Old Jan 18, 2006 | 11:31 AM
iam7head's Avatar
Default Re: (v4lu3s)
is the 91 accord cable driven? meaning there's a cable that actually turns at the tranny to the cluster?
on my 89 legend, the tacho stop working one day is because the cable fail off the cluster slot
Old Jan 18, 2006 | 11:43 AM
Phaulkyou's Avatar
Default Re: (iam7head)
The tach wont be run off the same cable, that cable would only drive the speedo. Normally the tach would be driven off the grounded wire from the main body harness.
Old Jan 18, 2006 | 11:58 AM
Brain3208's Avatar
Default Re: (Phaulkyou)
Yea i had this problem multiple times on my old rex's, Gonna pull apart the distributor.
thanks guys
Brain
TheRookie74
Sep 13, 2014 06:05 AM
kulangot
Feb 18, 2009 07:08 PM
regal1975
May 29, 2007 06:05 AM
TheAccordGuy
May 27, 2006 02:53 PM
frostee trooper
Feb 6, 2005 10:58 PM
