hot air
Old Jan 18, 2006 | 07:07 AM
honda4674's Avatar
Default hot air
ok so i replaced my heater blower and boy was that fun(note sarcasim) but it still dosent get hot in the car and i have the thing all the way in the red any ideas im so lost thanks
Old Jan 18, 2006 | 07:38 AM
SpankyG's Avatar
Default Re: hot air (honda4674)
You could have a bad heater cable, if you look under your hood and follow your heater hoses to where they go into the firewall on one of the hoses you should see a metal valve looking thing with a cable attatched to it. These will be the smaller diameter hoses, you should have one running from your water pump, and i believe that they go in somewhere close to the center of the firewall, but i could be wrong. Watch this and have someone turn your heater **** from hot to cold, if it doesn't move, then you have a bad cable. There is also a possibility that your heater core could be blocked, I am not sure as to the best way to check for this other than changing it or taking the core to a radiator shop. Hope this helps.
Old Jan 18, 2006 | 08:31 AM
Brain3208's Avatar
Default Re: hot air (SpankyG)
Clogged heater core, Possibly have an air pocket in the core also.
Have you checked the fluid level lately?
Brain
Old Jan 19, 2006 | 07:23 AM
honda4674's Avatar
yha but it needs to get flushd bad thanks for all the help guys god i love this site
Old Jan 19, 2006 | 07:47 AM
HondaAccordTdR's Avatar
Yeah wear a jacket
Old Jan 19, 2006 | 07:49 AM
amckee's Avatar
Default Re: (honda4674)
First, look under the dash on the right side of the console where the carpet meets the firewall. There is a white bellcrank that the temp **** actuates. Watch this while moving the temp **** to see if it moves it all the way. You can actuate it with your hand to see what all the way is. This will tell you whether or not the **** is stripped. Then as the previous poster said, check the function of the bypass valve under the hood. If both of these are OK, I would disconnect both the inlet and outlet hose on the heater core and check for flow with a water hose. If it appears restricted, alternate between the inlet and outlet with good pressure until it flows freely. I take it your not experiencing any overheating and this is strictly a heater issue?
Old Jan 19, 2006 | 07:58 AM
honda4674's Avatar
nope no over heating at all
Old Jan 19, 2006 | 08:08 AM
amckee's Avatar
Stripped temp **** is the most common problem. They are only $5 or so from the dealer if that turns out to be your problem. I keep a spare in the glove box. I'm on my third **** so far. Woman seem to think that the car will warm up faster if they turn the **** faster and harder. Go figure.
Old Jan 20, 2006 | 06:53 AM
honda4674's Avatar
haha you know i have noticed that from my G/F but i went to the junk yard lookd around found one that was clean and straight and i went home and put it in and you know what nothing i think its the cable cause when i took the old one out it was messed up but it could still turn freely and now the new(used) one cant so where does that cable go and how do i go about fixking it
Teggy_DC2
Feb 11, 2016 12:29 AM
sarah007
Jan 1, 2008 08:40 AM
BRAGAN
May 31, 2006 05:25 AM
TheIceMan
Feb 20, 2005 02:20 PM
misledyouth_is_back
10
Dec 26, 2003 09:40 PM
