Quick ? about sway baR
Old Jan 18, 2006 | 12:21 AM
john666's Avatar
Default Quick ? about sway baR
My friend totalled his 95 si hb.. if i take the sway bars off that car what would i need to make it fit onto my 94 dx hb ? Just the rear lca ? o yea front and back sway bars. ty for your time.
Old Jan 18, 2006 | 12:29 AM
Cute EK's Avatar
Default Re: Quick ? about sway baR (john666)
bolts
Old Jan 18, 2006 | 12:38 AM
thisisntjared's Avatar
you need the lcas but both sway bars will swap over... the eg si had swaybars?
Old Jan 18, 2006 | 01:19 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Quick ? about sway baR (thisisntjared)
You will need both the front and rear LCA's, as well as the D-clamps for the bushings, all related end-links and bolts.
Old Jan 18, 2006 | 09:20 AM
Default Re: Quick ? about sway baR (JDM_Ej)
o i also forgot. for the rear sway bar some of the hatches did not have nuts welded to the frame, in which case you would have to buy one. which would be annoying.
i had the nuts welded on mine so it wasnt a problem(will be when i get around to putting on my itr bar) a friend has had a coupe and a hatch, both of which had no nuts, just holes for where the nuts would be.
i hope we are all mature enough to talk about screws, nuts, and holes being in the place of nuts
Ed7touge
Mar 19, 2011 08:15 PM
B20EF
Jul 9, 2008 04:44 AM
doug07
Honda Civic (2001 - 2005)
Jun 11, 2006 09:44 AM
ek4 coupe
Sep 27, 2004 06:27 AM
