Plug wires
I'm thinking of upgrading the plug wires on my Accord. The two I've been eying are these http://store.summitracing.com/...=Make
or these
Has anyone used either on this car? I have the MSD's on my truck and like them so far.
or these
cant see anything try posting the pics, it has says to add make model year and all that other good stuff. However i heard MSD are good im running Tsudo 9.5 mm and hasnt let me down.
Has anyone used to Taylor ones I'm seriously considering those. I want to know why the plug wires for this Honda cost more than the ones for my Ram when the Honda only needs 4 wires my Ram needed 8 plus the coil wire and they all were a lot longer than the ones on the Honda.
I don't know why they cost more but...
Personally, I would just stick with factory plug wires. If you buy them from HAP or some other online dealer, you can get them cheaper than those two you posted. If you go to a local dealership, you should be able to get them cheaper than the MSD wires and for about the same price as those Taylor wires.
I had those MSD wires on my F22B1 for about 6 months before I totalled the car, they make no difference. I actually still have them on the motor and will most likely be taking them off and replacing them with factory wires when I rebuild the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noobie »</TD></TR><TR><TD CLASS="quote">by far,, the best plug wires you can get,,,,,,,,,beleve it or not,,, it is the factory honda plug wires ,,,,all the other stuff might look good but it will perform worse </TD></TR></TABLE>
amen, first thing you need to do is test the resistant of the wire with a multi meter, if it's within factory spec, there's no reason to replace them.
ngk stock is proven to have the most stable vs. aftermarket spark "hose"
I can get the ones from Summit cheaper as I have a $20 off thing. I may go OEM although I don't really like OEM and would like bigger wires.
I don't know if they need to be replaced but they haven't been in a while so I don't think it would be a bad idea to go ahead and replace them.
Anyone know if the Honda's have a coil wire like some other vehicles do? I'm to lazy to go out and look.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">I can get the ones from Summit cheaper as I have a $20 off thing. I may go OEM although I don't really like OEM and would like bigger wires.
Anyone know if the Honda's have a coil wire like some other vehicles do? I'm to lazy to go out and look. </TD></TR></TABLE>
Just so i throw this in...........In a recent DYNO test among many plug wires,,,,,,,,,The factory plug wires outperformed them all...............
do not be lured in by all the fancy colors, or advertisment stick with factory Honda wires
If you're just going with regular wires... as many have said, stick with the factory ones. However, you may want to look into hot wires. Nology makes some good ones. They condense electrical energy and send a stronger current to your plugs resulting in a stronger spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">I can get the ones from Summit cheaper as I have a $20 off thing. I may go OEM although I don't really like OEM and would like bigger wires. </TD></TR></TABLE>
I would save that $20 off for something else and buy factory plug wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">Anyone know if the Honda's have a coil wire like some other vehicles do?</TD></TR></TABLE>
You mean the wire that would run between the distributor cap and an external coil?
Some Hondas do, but your F22B1 has an internal coil so there is no extra coil wire running outside of the cap. Just four plug wires running from the cap to the spark plugs, nothing more.
is it worth upgrading the plugs/wires on my 04? would it be worth it to get the hot wires? (I'm asking this because you guys were talking about the 96, wasn't sure if there was a difference between the generations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msedacca »</TD></TR><TR><TD CLASS="quote">is it worth upgrading the plugs/wires on my 04? would it be worth it to get the hot wires? (I'm asking this because you guys were talking about the 96, wasn't sure if there was a difference between the generations)</TD></TR></TABLE>
Just stay with OEM Honda. I wouldn't think you would need to replace them just yet, but to be sure, just check them with a multimeter and see if they are within specs. If so, leave them alone, if not, replace them.
NGK or Denso with factory gap specs.
The numbers listed below are from the Helm manual.
F22B1 & F22B2
<U>For all normal driving</U>
ZFR5F-11 (NGK)
KJ16CR-L11 (Denso)
<U>For hot climates or continuous high speed driving</U>
ZFR6F-11 (NGK)
KJ20CR-L11 (Denso)
Electrode Gap = 1.1mm or .043"
F22B1 & F22B2
ZFR5F-11 (NGK)
KJ16CR-L11 (Denso)
ZFR6F-11 (NGK)
KJ20CR-L11 (Denso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">NGK or Denso with factory gap specs.
F22B1 & F22B2
ZFR5F-11 (NGK)
KJ16CR-L11 (Denso)
ZFR6F-11 (NGK)
KJ20CR-L11 (Denso)
Electrode Gap = 1.1mm or .043"</TD></TR></TABLE>
actually the gap spec is .040 to .044.........set plugs to the smallest gap,, in this case .040,, because as they wear gap will get bigger ..if you set them at .043 to start with then gap will be wider,(out of specs ) sooner
F22B1 & F22B2
ZFR5F-11 (NGK)
KJ16CR-L11 (Denso)
ZFR6F-11 (NGK)
KJ20CR-L11 (Denso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noobie »</TD></TR><TR><TD CLASS="quote">actually the gap spec is .040 to .044 </TD></TR></TABLE>
Are you saying that .040-.044" is for 5th gens or a different year? Cause in my Helm manual for a 95 Accord, 1.1mm or .043" is the spec listed for F22B1 and F22B2 motors.
Rob.
Sep 9, 2009 07:32 PM
