Custom NA intake manifold, interested in fab'ing for me?
Old Jan 17, 2006 | 08:15 PM
rjay8604's Avatar
Default Custom NA intake manifold, interested in fab'ing for me?
**NO LONGER NEED MANIFOLD, BEYOND MY CURRENT BUDGET** Thanks to all who replied.
I have been trying to get the last few HP out of my 202whp 1.8 B-series. I know a lot of you guys are very skilled fabricators. I was thinking one of you guys could build me a manifold for less than $1000 that would be more affordable and more practical for me than a ITB setup. I could provide my b16 manifold as a core for the flange and any other uses.
I had a few ideas I'm interested in for the manifold:
Each runner ends with a velocity stack raised off the plenum floor.
Utilizes a mustang throttle body bolt pattern for an affordable 70mm TB.
Has direct port nitrous bungs ready. (100 shot for extra fun when needed )
Throw any ideas you may suggest in as well.
Thanks for looking and hope some of you may have some interest.
Modified by rjay8604 at 10:12 PM 1/22/2006
Old Jan 17, 2006 | 09:18 PM
k24em2's Avatar
Default Re: Custom NA intake manifold, interested in fab'ing for me? (rjay8604)
I don't know that you would need someone to build one. Full-Race makes one already that has nearly all the requirements you listed, and is sub-$1000. Check that one out.
Old Jan 17, 2006 | 09:31 PM
rjay8604's Avatar
Default Re: Custom NA intake manifold, interested in fab'ing for me? (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know that you would need someone to build one. Full-Race makes one already that has nearly all the requirements you listed, and is sub-$1000. Check that one out.</TD></TR></TABLE>
Thanks for the heads up. I m currently talking to dk-fabrications and it is sounding pretty good.
Modified by rjay8604 at 1:29 AM 1/18/2006
Old Jan 18, 2006 | 06:35 PM
CRVRX's Avatar
at 202 whp . the intake manifold isn't what's holding you back. Not saying you shouldn't get one , but we've made 235whp+ on stock ITR manifolds
What's your set up ?
Old Jan 18, 2006 | 06:40 PM
discrete's Avatar
Yeah, shouldnt headwork be done first?
Old Jan 18, 2006 | 07:49 PM
JG-Fabrications's Avatar
Default Re: (discrete)
I could build you an intake manifold, pm about it
-James
Old Jan 18, 2006 | 08:28 PM
rjay8604's Avatar
Default Re: Custom NA intake manifold, interested in fab'ing for me? (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">at 202 whp . the intake manifold isn't what's holding you back. Not saying you shouldn't get one , but we've made 235whp+ on stock ITR manifolds
What's your set up ?</TD></TR></TABLE>
I would believe although mine may not be "holding me back" an optimized IM could potentially give me some decent gains. I think i'm not getting the full benfit of the head port and polish without a port/polished intake manifold. Also I'd like a custom one so the nitrous bungs could be integrated in the manifold.
1847cc
11.2:1 compression
81.4mm stroke b17a crank
85mm bore GE sleeves
portflow port & polish, valve job, b16 head
RMF header
2.5 straight through exhaust
AEBS intake manifold
Blox B cams (copy of skunk2 stage 2's)
Fully tuned with neptune.
Whale ***** CF intake.
64mm civic si overbored throttle body
Here's the dyno
Old Jan 19, 2006 | 12:22 AM
lucidvtec's Avatar
what do u think about the AEBS mani.....i have it as well...not to many people do.....it's cheap...but looks alot better flowing than the stock
Old Jan 19, 2006 | 06:58 AM
Chase's Avatar
Default Re: (lucidvtec)
Yeah, the full-race sounds like what your lookin for.
But you know the AEBS has the nitrous bungs on the bottom, and u could send it off to import builders or somethin and have em cut it, port the hell out of it, and weld it. Just make sure its port matched
Good luck
Old Jan 20, 2006 | 05:31 AM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">
1847cc
11.2:1 compression
RMF header
try looking at the tech43 kit.
Seems to be that its the cam's and compression thats holding you back.
Old Jan 21, 2006 | 11:53 AM
onefstek's Avatar
sounds like you need what I just built for my car. but with a gsr flange. i might post pics if you guys are interested.
Old Jan 21, 2006 | 05:59 PM
rjay8604's Avatar
Default Re: (onefstek)
Post some pics up. Is it for a turbo setup? Mine will be for NA. Anyway, i'd like to see yours.
Old Jan 22, 2006 | 07:10 PM
onefstek's Avatar
Default Re: (rjay8604)
here are a couple of pics. one from inside the plenum and one of the t/b flange. 80mm diameter.
Old Jan 22, 2006 | 07:37 PM
rjay8604's Avatar
Damn, that look really nice, especially the velocity stacks. Hope you have some good results with it.
Old Jan 22, 2006 | 08:51 PM
AllmotorEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote"> here are a couple of pics. one from inside the plenum and one of the t/b flange. 80mm diameter.
Nice work Stefan looks great man
Old Jan 24, 2006 | 10:09 PM
preludeserge's Avatar
Where did you get those velocity stacks? What's the ID on those? Those aren't RMR ones, or are they?
Old Jan 26, 2006 | 12:00 PM
onefstek's Avatar
Default Re: (preludeserge)
Dimensions are, 42 mm Base ID with 64 mm Belllmouth OD. One of my friends got them for me.
Old Jan 26, 2006 | 12:05 PM
bigdaddyvtec's Avatar
* B A N N E D *
Nice stefan, thanks for beading my IC pipes too, no more issues!!
Brian
BlackCivicEX
May 24, 2011 11:39 AM
gezzuzz
Apr 13, 2008 07:40 PM
queez
Dec 9, 2003 09:41 AM
SilverEP3
May 3, 2002 02:43 AM
