dart short block
i have a standard deck dart block 84mm, eagle 89mm crank, eagle rods 2000arp bolts, wiseco custom 9.5 to 1 pistons, type r oil pump, and rear main seal
this is used has about 5000 miles on it.
i will have pics up in a day or two when i get it out of the car
i also have extra rings for the pistons
i need to sale to biuld new motor so will let go for 2800 dollars
i need some parts for my other dart block that is going to be big bore
and 95mm stroke
david
330-310-9151
Modified by b20dave at 8:31 PM 1/17/2006
and 95mm stroke
david
330-310-9151
hey sorry for the lowball but i have $1500. I know not nearly as much as u asked but thats all I have and thought i'd give it a try. and im assuming its a b20?...if anything , bump for u
i personally would rebuil it still ran good and had comp # 205,205,200,and210
before i pulled it there is some scratches on the walls
the oil presure was ok cold 60 psi at idle hot dropped to 15 or so at 800rpm at 185 degree oil engine hot ran 200 degree water
sorry to low
i do have one for $1900 that needs rebuilt. it is at 84.69 overall bore right know thats a very large 84mm to tight for 84.5 thou
all othr specs are the same
let me know
let me know
