Stripped valve cover stud...how hard to replace?
The bottom left stud is stripped because the nut just keeps spinning and wont come off. Once i get the new stud, how hard is it to replace?
example
example
Uh, unbolt it with a deep socket, bolt new stud in. Pretty easy. I grab the studs at pick a parts all the time, since so many get stripped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markw »</TD></TR><TR><TD CLASS="quote">Uh, unbolt it with a deep socket, bolt new stud in. Pretty easy. I grab the studs at pick a parts all the time, since so many get stripped.
ok thanks, 10 or 12mm?
</TD></TR></TABLE>ok thanks, 10 or 12mm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 »</TD></TR><TR><TD CLASS="quote">Read the link in my sig</TD></TR></TABLE>
that thread says they might be 10mm, they do look a little smaller than the cam cap bolts which are 12. And what are the torque specs?
not sure on the torque... thats a good question. i have never toqued those. prob why i strip them all of the time.. lol... maybe try the other link in my sig the one for zc info might have the toque specs there hope that helps
shyt i hate these bolts. I go to replace the cam seal and one of the 12 mm bolts that hold the cam plate in snapped in half. The bolts were torqued waay too tight and i think it snapped when i loosened them.
I gotta keep a bunch of these bolts as spares.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 »</TD></TR><TR><TD CLASS="quote">shyt i hate these bolts. I go to replace the cam seal and one of the 12 mm bolts that hold the cam plate in snapped in half. The bolts were torqued waay too tight and i think it snapped when i loosened them.
I gotta keep a bunch of these bolts as spares.</TD></TR></TABLE>
I was in that exact same boat as you man. I replaced the seal near the vtec solenoid. Upon re-assembly I broke a stud on the cam bracing piece and also a valve cover stud.
I didn't think that I could just unbolt the VC stud. I just suckkered that thing up with Hondabond and called it a day.
it's lasted 600 miles so far.
I gotta keep a bunch of these bolts as spares.</TD></TR></TABLE>I was in that exact same boat as you man. I replaced the seal near the vtec solenoid. Upon re-assembly I broke a stud on the cam bracing piece and also a valve cover stud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex »</TD></TR><TR><TD CLASS="quote">vice grips
that's how I got around 8 of mine out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si »</TD></TR><TR><TD CLASS="quote">i think torque is 9 ft/lbs</TD></TR></TABLE>
Pretty sure ur correct.
</TD></TR></TABLE>that's how I got around 8 of mine out.
they are correct but use a inch pounds bar...i learned the broke way
saddler263
12
Aug 28, 2008 10:08 AM
schwinnrex
11
Apr 7, 2007 12:01 PM
Esdelota
10
Oct 18, 2006 05:50 AM
