I have a 92 hatchback... I need a stock radio.... would any honda radio fit the same stock raido har
I have a 92 hatch and I want to get a stock radio... I was thinking about getting a s2000 radio/cd player... but most people sale these without the harness to the back radio.... So Im woundering if my stock raido harness would plug into it without problems? so what year radio would work on my stock harness.
Just about any Honda/Acura oem HU up to 1997/98 will work http://www.installdr.com/Harnesses/HA-Wiring.pdf
As you can see newer then 98 use a diff. plug, also the S2000 uses a diff. mounting system as your 92 hatch.
94
94
As fcm said, any Honda radio through model year '98 will be plug and play. Newer radio will require two harnesses. One 70-1720 to plug into your existing harness in the car, and one 71-1721 to plug into the newer radio... Wire them up color to color (just like you were installing an aftermarket deck) and you'll be in business.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">As fcm said, any Honda radio through model year '98 will be plug and play. Newer radio will require two harnesses. One 70-1720 to plug into your existing harness in the car, and one 71-1721 to plug into the newer radio... Wire them up color to color (just like you were installing an aftermarket deck) and you'll be in business.</TD></TR></TABLE> Ditto that.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand »</TD></TR><TR><TD CLASS="quote">fitment dont matter.... just fineing the s2000 or 99 up harness well be the hard part. </TD></TR></TABLE> Yes "fitment" will matter, you will have to be able to keep the HU in the dash, and the harnesses B18_EJ8 mentioned can be found at most car audio shops.
94
94
BlueIntegraBoy
Jun 21, 2008 11:17 AM
apm
Apr 11, 2008 09:20 PM
1slowcrx
Sep 24, 2006 07:28 PM
Black R
May 22, 2001 09:30 PM
