HELP...vtec solenoid gasket for jdm b16a
Old Jan 17, 2006 | 03:40 PM
Junkyard2000's Avatar
Default HELP...vtec solenoid gasket for jdm b16a
I did some research and everyone said to go with the 91 nsx for a 1st gen jdm b16. I finally took off the solenoid and the old gasket is flatter and squarish and the new one i got is rounder. When i put the new one in, theres a tiny bit of space as you can see from the pic below. Is this gonna be a problem? Should i use the new one and just use alot of hondabond? or stick with the old one?
old, new
new one
old one
Old Jan 17, 2006 | 03:41 PM
Malgerus's Avatar
Default Re: HELP...vtec solenoid gasket for jdm b16a (Junkyard2000)
My guess is that your old gasketis just compressed from age. The new one should work fine. You can honda bond it too if you like.
Old Jan 17, 2006 | 03:43 PM
UltimX's Avatar
You should be fine unless where the point is on the first gasket "<" in the first pic, it looks like thers a crack inbetween the 2, if so, put honda bond, if not , you should be cool.
Default Re: HELP...vtec solenoid gasket for jdm b16a (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">My guess is that your old gasketis just compressed from age. The new one should work fine. You can honda bond it too if you like.</TD></TR></TABLE>
Thats what i was thinking, so where should i hondabond it? everywhere there is space?
Old Jan 17, 2006 | 03:44 PM
Default Re: HELP...vtec solenoid gasket for jdm b16a (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">You should be fine unless where the point is on the first gasket "&lt;" in the first pic, it looks like thers a crack inbetween the 2, if so, put honda bond, if not , you should be cool.</TD></TR></TABLE>
yea the old gasket has a couple of tiny rips and the screen was out of place also.
Old Jan 17, 2006 | 03:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The main difference I see is the old one has been
bolted down and compressed..
The new one is still round and the old one is kinda squashed...
I just used permatex ultra-gray on the old gasket on my friends
car.. The gasket was still soft but it was leaking bad.
Old Jan 17, 2006 | 05:28 PM
Default Re: HELP...vtec solenoid gasket for jdm b16a (88DXCRX)
well, i just used the new one and hondabonded it.
egsleepercivic
20
Mar 14, 2023 10:00 AM
Justef Datshiet
Jan 8, 2013 08:20 PM
Jason Nucom
Nov 27, 2012 06:23 PM
wood 1
Aug 31, 2007 01:29 PM
91HATCH
19
Jun 9, 2004 10:25 AM
