Recall P21
I haven't seen a recall notice from Honda but when I got my registration paperwork from the DMV they want proof that recall P21 was done. Anyone know what this is.
"98 Accord
"98 Accord
Here are the active recalls for the '98 accord (5):
You'll have to show up and have Honda check if any are active (DMV says yes), and have them repair it. The copy of the repair order will be proof for the DMV that it's been done.
These recall notices may not apply to all vehicles. Please contact your dealer for more details or contact the National Highway Traffic Safety Administration's Auto Safety hotline at 1-888-DASH-2-DOT (1-888-327-4236).
Campaign Number: 03V423000 Date: 2003-Oct-27
Component: Electrical System: Ignition: Switch
Defect Summary: ON CERTAIN PASSENGER VEHICLES AND MINI VANS, THE IGNITION SWITCH MAY WEAR EXCESSIVELY AND PREVENT PROPER INTERLOCK OPERATION, MAKING IT POSSIBLE TO TURN THE IGNITION KEY TO THE “OFF” POSITION AND REMOVE THE KEY WITHOUT SHIFTING THE TRANSMISSION TO "PARK."
Consequence Summary: IF THE VEHICLE OPERATOR DOES NOT SHIFT TO "PARK" BEFORE REMOVING THE KEY AND FAILS TO ENGAGE THE PARKING BRAKE, THE VEHICLE COULD ROLL AND A CRASH COULD OCCUR.
Corrective Summary: DEALERS WILL PERFORM AN INSPECTION PROCEDURE THAT DETERMINES THE AMOUNT OF CYLINDER BODY WEAR. IF SIGNIFICANT WEAR IS INDICATED, THE DEALER WILL REPLACE THE CYLINDER BODY, COLLAR, AND LATCH PLATE. IF NO SIGNS OF WEAR ARE INDICATED, DEALERS WILL REPLACE THE LATCH PLATE WITH A REDESIGNED PART. OWNER NOTIFICATION BEGAN DECEMBER 8, 2003. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
Campaign Number: 02V120000 Date: 2002-May-16
Defect Summary: ON CERTAIN SEDANS, COUPES, HATCHBACKS, AND SPORT UTILITY VEHICLES, ELECTRICAL CONTACTS IN THE IGNITION SWITCH CAN DEGRADE DUE TO THE HIGH ELECTRICAL CURRENT PASSING THROUGH THE SWITCH WHEN THE VEHICLE IS STARTED.
Consequence Summary: WORN CONTACTS COULD CAUSE THE ENGINE TO STALL WITHOUT WARNING, INCREASING THE RISK OF A CRASH.
Corrective Summary: DEALERS WILL REPLACE THE IGNITION SWITCH. OWNER NOTIFICATION BEGAN JUNE 14, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
Campaign Number: 99V069000 Date: 1999-May-10
Component: Suspension: Front: Control Arm: Lower Ball Joint
Defect Summary: VEHICLE DESCRIPTION: PASSENGER VEHICLES. CERTAIN VEHICLES WERE MANUFACTURED WITH BALL JOINTS THAT CAN PREMATURELY WEAR OUT AND, IN THE WORSE CASE, THE BALL JOINT WOULD SEPARATE CAUSING THE FRONT SUSPENSION TO COLLAPSE.
Consequence Summary: THIS CONDITION WOULD RESULT IN VEHICLE DECELERATION AND A SUDDEN LOSS OF POWER. ALSO STEERING CONTROLLABILITY WOULD BE REDUCED.
Corrective Summary: DEALERS WILL REPLACE THE FRONT SUSPENSION LOWER BALL JOINTS.
Campaign Number: 98V018000 Date: 1998-Feb-10
Component: Power Train: Automatic Transmission: Park/neutral Start Switch
Defect Summary: VEHICLE DESCRIPTION: PASSENGER VEHICLES (HONDA ACCORD SEDANS MANUFACTURED FROM SEPTEMBER 18, 1997 TO JANUARY 10, 1998; COUPES MANUFACTURED DECEMBER 11, DECEMBER 15, 1997, AND JANUARY 5, 1998; ACURA 2.3CL MANUFACTURED OCTOBER 22, 1997 THROUGH JANUARY 7, 1998). DURING MANUFACTURING, THE CASTING DIE CAUSED AN IRREGULARITY IN THE RIGHT-SIDE TRANSMISSION COVER. THIS IRREGULARITY CAN LIMIT THE MOVEMENT OF THE PARKING PAWL ACTUATION LEVEL AND PREVENT ADEQUATE ENGAGEMENT OF THE PARKING GEAR PAWL. THIS DOES NOT COMPLY WITH FMVS NO. 114, "THEFT PROTECTION."
Consequence Summary: THIS CONDITION CAN CAUSE THE VEHICLE TO ROLL DOWN AN INCLINE WHEN THE TRANSMISSION IS LOCKED IN "PARK," INCREASING THE RISK OF PERSONAL INJURY AND/OR PROPERTY DAMAGE.
Corrective Summary: DEALERS WILL INSTALL A COLLAR ON THE TRANSMISSION PARKING PAWL TO ENSURE PROPER MOVEMENT OF THE ACTUATION LEVER.
Campaign Number: 97V220000 Date: 1997-Dec-16
Component: Seat Belts: Front: Anchorage
Defect Summary: VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE FRONT PASSENGER SEAT BELT RETRACTOR MOUNTING BRACKET WAS IMPROPERLY WELDED.
Consequence Summary: THIS CONDITION CAN CAUSE THE BRACKET TO SEPARATE FROM THE VEHICLE BODY IN A CRASH.
Corrective Summary: DEALERS WILL INSPECT AND REPAIR THESE VEHICLES.
P
P
look for a center punch above the the VIN in the 9th or 10th position. Take your car to the honda dealer and have then run the Vin or inspect the stamped VIN on the engine block. They will be able to tell you if it was done and if needed complete the required form for you.
jim321
Jul 8, 2013 06:50 AM
1320performancefreak
Mar 7, 2006 10:48 AM
