How to check Cooling Fan Relay?
Old Jan 17, 2006 | 02:34 PM
Nisif's Avatar
Default How to check Cooling Fan Relay?
My cooling fan won't turn on in my civic. I'd like to check if the relay is good or bad so I can determine if I need a new one or a new thermoswitch. I jumped the plug at the thermoswitch and both the a/c and cooling fans turn on. How can I check the relay, and is it located above the radiator fan?
Old Jan 17, 2006 | 02:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: How to check Cooling Fan Relay? (Nisif)
If you jumped the thermoswitch and the fans
came on then it is probably the thermoswitch..
You jumped the switch and it runs..
That in itself indicates the relay is working..
Old Jan 17, 2006 | 03:01 PM
jlicrx's Avatar
the radiator fan relay doesn't show up too well in these pictures - it is on the inner fender panel behind the passenger side headlight - the condenser fan relay is on the bulkhead between the headlight and radiator
hmtcrxsir
16
Apr 9, 2017 11:13 PM
roni_xxp
Feb 22, 2009 06:35 PM
SiMateoAko
Jul 5, 2005 08:11 AM
spiceisler
Jun 24, 2004 08:46 AM
