Kill Switches, What is the best place to tap into the harness so it is not so obvious??
Old Jan 17, 2006 | 02:22 PM
Brain3208's Avatar
Default Kill Switches, What is the best place to tap into the harness so it is not so obvious??
Sup everyone!
Well my accord is running good, shifting great!.....Still a slow *** POS but i'm hoping it will last me at least till i can get outa the neighborhood i'm in so i can buy my damn 4th or 5th(lost count) Crx. I look at it like this....i can drop an H22 head onto my block, already installed the Nitrous setup, Put together a custom Turbo kit for the summertime and once i move outa this shithole we call philly i can transfer everything over to a CRX Shell again.
My question is this....I have installed 3 kill switches on the car in various locations and wired them accordingly. i was going to wire them directly into the fuel tank connector(under my rear seat) but most theives know how to get around that one fairly easy. is their a Bettter place to splice my switches into the harness? what's under the connector panel? can i splice it elsewere that average breakin(crackhead) thieves will not find?
TIA All!
Brain
Old Jan 17, 2006 | 03:02 PM
YeuEmMaiMai's Avatar
Default Re: Kill Switches, What is the best place to tap into the harness so it is not so obvious?? (Brain32
wire one to one of your ignition wire fuses
Old Jan 17, 2006 | 04:21 PM
SteveoBA8's Avatar
Starter cut switch
Old Jan 17, 2006 | 04:53 PM
Brain3208's Avatar
I'm thinkin Lock-up control Kill so they can't put it into drive but i don't know how that works when the car is off. would that be effective at all so at least if they manage to get it running they can't put it into gear.
brain
Old Jan 17, 2006 | 05:25 PM
P_Adams's Avatar
Well, the moment I suggest it, it'll be out of the bag; now won't it?
Why not interupt the starter circuit at the shifter park switch and bury the switch in the console armrest compartment.
I go it one better by using a key lock on/off switch from alarm suppliers.
Back the switch with a piece of sheet metal, and the only way to start it would be to pull apart the entire console.
P
Old Jan 17, 2006 | 06:25 PM
accordisslow's Avatar
Interesting How can i put a kill switch on my car? what can i do and how can i do it? anyone, also what does it do besides not letting the engine turn on.
Old Jan 17, 2006 | 07:37 PM
SteveoBA8's Avatar
Get a wiring diagram, decide where you want a switch.
Old Jan 17, 2006 | 11:04 PM
raceACCORDingly's Avatar
fuel cut off switch off the main relay.
Old Jan 18, 2006 | 06:27 AM
Brain3208's Avatar
Default Re: (raceACCORDingly)
I like the fuel cuts but i don't wanna put it on the usual places, like the relay, i would like to cut somtthing off behind the fuse panel if possible so i can hide all wiring. i'm gonna prolly have a ECU cutout , and Ignition Cut.
Brain
Old Jun 11, 2007 | 11:29 AM
akdrag's Avatar
P_Adams is a bad bad man, holy smokes that's a sick plan! if I had the time and know how I'd do that exact thing sounds legit!
Old Jun 11, 2007 | 11:54 AM
TheMuffinMan's Avatar
He knows where you live!
1.5 year bump ftw?
Old Jun 11, 2007 | 12:47 PM
Eddiebx's Avatar
i guess its cuz he's a really really bad bad man
Old Jun 11, 2007 | 01:04 PM
methodical's Avatar
old *** thread FTW
Rand The Man
Audio / Security / Video
11
Aug 15, 2012 11:50 PM
HonDelso
Aug 2, 2008 12:50 AM
hitekper4mance
Oct 9, 2007 08:21 AM
matt2001teg
Nov 3, 2003 07:25 PM
