im stuck plzzz help
Old Jan 17, 2006 | 02:01 PM
deeweezy187's Avatar
Default im stuck plzzz help
i want to start my sohc monster project but stuck on which engine to start on. I want to do a f22b1. But in my car is a f22b2. Which engine would you guys turbo. I was goin for the f22b2 but want to know if i can use aftermarket parts from a f22b1 like a skunk2 thorttle body and a venom intake manifold.
Old Jan 17, 2006 | 02:16 PM
YeuEmMaiMai's Avatar
Default Re: im stuck plzzz help (deeweezy187)
if then engine in your car is in good shape, turbo it.
Old Jan 17, 2006 | 02:44 PM
anybody else
Old Jan 17, 2006 | 08:31 PM
P_Adams's Avatar
The F22b2 SOHC Non V-Tec lends itself well to Turbo. Besides being dirt cheap to replace if you need to, the bottom end and piston ring lands are stronger than some other series.
The F22b1 SOHC V-Tec version lends itself better to all-engine applications. Surprisingly, the aggressive cam lobe profiles which work quite well w/v-tec actually work against boost horse power
P
Old Jan 17, 2006 | 11:04 PM
raceACCORDingly's Avatar
if it will bolt onto an f22b1 it will bolt on to the b2.
Old Jan 17, 2006 | 11:40 PM
iam7head's Avatar
Default Re: im stuck plzzz help (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">The F22b2 SOHC Non V-Tec lends itself well to Turbo. Besides being dirt cheap to replace if you need to, the bottom end and piston ring lands are stronger than some other series.
P </TD></TR></TABLE>
tunning is much easier too, the famous spike after vtec engage on boost
smith.j@wrxsti
Engine Management and Tuning
Dec 25, 2012 04:21 AM
tambara
Nov 26, 2007 01:23 PM
dipsetking
Nov 21, 2006 01:39 PM
85ES3
Mar 16, 2006 06:24 PM
Hawks-At-Angels-12
Feb 4, 2006 12:44 PM
