about a free d15b7
Old Jan 17, 2006 | 12:58 PM
kantfadedisazn's Avatar
Default about a free d15b7
i dont know if i should take it but i can get a free d15b7, the only problem is that cylinder #1 has a compression of 25 what could be the problem sawwie if i dont no much but i could use the help
Old Jan 17, 2006 | 01:39 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: about a free d15b7 (kantfadedisazn)
well. a couple of things come to mind. first of all, i would take it no matter what is wrong with it, if it is free. you can always tear it apart before you put it in to make sure there is nothing wrong with it.
now as for what could be wrong with it. if compression is 25 in #1, then i would suspect either the piston rings have seen better days, or one of the valves is bent from any one of many reasons. you can check this by pouring oil down the #1 sparkplug hole, just a little, like a teaspoon, and redo the compression test. if the number is higher, say like 100psi, then the rings are fried and need to be replaced. if the compression stays around 20 after the oil test, then it may be a bent valve or valves. youll have to take the head off to figure out which one, or ones.. but that should get you started.
even if the block or the head or both turn out to be complete junk, some major cities have metal recyclers that will pay you a little bit of money to recycle the block.. so either way it is win win.. i just wouldnt suggest swapping it into your car until you know what the problem is.. unless your car isnt a daily driver.
good luck.
Old Jan 17, 2006 | 01:46 PM
Default Re: about a free d15b7 (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">well. a couple of things come to mind. first of all, i would take it no matter what is wrong with it, if it is free. you can always tear it apart before you put it in to make sure there is nothing wrong with it.
good luck.</TD></TR></TABLE>
thanks ill probly take it and find out, is thats the dx or cx motor?
Old Jan 17, 2006 | 02:38 PM
SVOboy's Avatar
DX = D15B7 16 Valves
CX = D15B8 8 Valves
Old Jan 17, 2006 | 02:43 PM
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">DX = D15B7 16 Valves
CX = D15B8 8 Valves</TD></TR></TABLE>
kool thanks for the info mangz
dmonk87
Dec 3, 2011 05:27 AM
iplayloudly
Nov 23, 2008 08:00 PM
misternguyen
Feb 18, 2007 01:24 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
lsvtec42
Dec 6, 2001 12:39 PM
