ITR Rear spoiler authentic?
Old Jan 17, 2006 | 12:39 PM
Solscud007's Avatar
Default ITR Rear spoiler authentic?
HJey you ITR guys. I got an OEM ITR rear wing. It has "Honda" stamped on the bottom of it where the spoiler touches the hatch. But the thing Im worried about is that it uses bolts. As opposed to my GSR spoiler has the bolts built into the spoiler and you have to uses nuts to screw it on. Were there ITR spoilers that use bolts that bolt underneath the hatch and go into the spoiler? or is this a good knock off?
Old Jan 17, 2006 | 12:41 PM
Skelly's Avatar
Default Re: ITR Rear spoiler authentic? (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">HJey you ITR guys. I got an OEM ITR rear wing. It has "Honda" stamped on the bottom of it where the spoiler touches the hatch. But the thing Im worried about is that it uses bolts. As opposed to my GSR spoiler has the bolts built into the spoiler and you have to uses nuts to screw it on. Were there ITR spoilers that use bolts that bolt underneath the hatch and go into the spoiler? or is this a good knock off?</TD></TR></TABLE>
Itr should be the same as your Gsr with the bolt stud in the wing and you would use nuts to tighten it down. Maybe the prior owner replaced them with bolts b/c the origional studs came loose?
Old Jan 17, 2006 | 12:46 PM
ninetail
Guest
Posts: n/a
Default Re: ITR Rear spoiler authentic? (Skelly)
i came across that problem once, the studs are removable... so, it looks like instead of throwing a 10' nut, u gotta throw in a 10' screw... or replace the stud
10' nut or skrew works all the same for me...
Old Jan 17, 2006 | 12:48 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: ITR Rear spoiler authentic? (ninetails)
Mine has the nuts on the bottom.
Old Jan 17, 2006 | 12:53 PM
Dave_B's Avatar
Default Re: ITR Rear spoiler authentic? (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Mine has the nuts on the bottom.</TD></TR></TABLE>
Old Jan 17, 2006 | 01:01 PM
cool guy name
Default Re: ITR Rear spoiler authentic? (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
maybe that was phrased wrong
Old Jan 17, 2006 | 01:07 PM
Solscud007's Avatar
best reply ever!!!!!!!
97hontegra
Nov 18, 2008 12:01 AM
OnePointFive
Oct 4, 2007 11:54 AM
Vero
Jun 7, 2007 10:27 PM
mr_mbuna
Jan 10, 2005 10:54 PM
fiebru1119
Apr 6, 2002 04:53 AM
