LS/VTEC Oil leak...
Okay. This is getting extremely irritating....
My motor has been running for about 4OOO miles now, and ive noticed i cant get rid of a small oil leak coming from under the solonoid area. First I though it was the distributor o-ring. Changed it, along with a new solonoid gasket, and it was fine for about a day. Then, the mystery leak came back. Ill keep spraying it off with brakleen, and it keeps coming back from the same spot, but i never catch it soon enough to see where its directly coming from. It sits on the top of the bellhousing where it meets the block, and it runs down the front of the tranny. Now, by no means is it A LOT of oil, its just that oils' molecular structure makes it look like more than it really is.
About a week ago, I cleaned it all off, and drove the car for about a mile. Now, when I pulled over, there was a teeny-weeny bit of oil around where the block code is and nowhere else. WTF?! Is it possible that my oil pan is leaking onto the back of my flywheel and kicking it all over the front of the inside-bellhousing? (I know, its very far-fetched, but Its a possibility)
If anyone has ever had this problem before, please key me in on a solution, because I know a couple of members going through the same problem.
the same damn thing is happening to me, the oil seeps out from somewhere onto my bellhousing and down my block, and it is extremely irritating, i am considering taking my gsr head off because i need a daily driver that is not going to leak oil
this is a common problem. oil is hard to spot unless it has dirt on it. therefor it could be leaking down, and then collecting dirt or pooling, making it more obvous.
check the following:
cam plug
vtec solinoid gasket
valve cover gasket
the bes thing to do, is rub your finger below the gasket area on the head and "Feel" where the oil is seeping from
cam plug
valve cover gasket
well, ive already changed all the possible gaskets, (except for the cam seal) anyone experience the same problem and have a common remedy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 »</TD></TR><TR><TD CLASS="quote">yea i put down some permatex as well</TD></TR></TABLE>
did you find out if it ended up working yet?
soHybridized
May 17, 2006 03:46 PM
