Need Motor Mounts
I need some new motor mounts for my H23 engine. But I dont just want the inserts, I have heard that they dont work very well...and if I am gonna get some I want some that work.
So anyhow, I did a search on here and found one company that makes them. http://www.innovativemounts.com
They are $309.99 for track series motor mounts...which is a bit pricey. So I was wondering before I spend that much if anyone had any info on them or if anyone had used them.
why do you need motor mounts designed for such high performance? is your motor stock? I wouldn't get anything different unless you really NEED motor mounts, or unless your h23 is a racecar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta »</TD></TR><TR><TD CLASS="quote">why do you need motor mounts designed for such high performance? is your motor stock? I wouldn't get anything different unless you really NEED motor mounts, or unless your h23 is a racecar</TD></TR></TABLE>
It is currently stock, but soon to be swapped and pushing 300+ HP.
So I am kinda looking to the future...No, it wont help my current motor that much...but I will need to get them anyhow when I swap.
yo ill tell you this much if you get those track series motor mounts everything is gonna vibrate so much that you not gonna be able to stand it. i needed some MM but for my h22 no body makes the inserts so i jus replaced the whole thing, couldnt find them no where so i had to go with the expensive one the dealership
goodluck
goodluck
