Putting 94 Integ ls front brakes on 93 del sol si
Old Jan 17, 2006 | 10:06 AM
1LOSTSOL's Avatar
Default Putting 94 Integ ls front brakes on 93 del sol si
I am putting the calipers/hubs/knuckles from a 94 integra ls on my 93 sol with a d16z6.
I was wondering if my stock CV axles will work?
TIA.
Old Jan 17, 2006 | 10:11 AM
pdiggitydogg's Avatar
since your si knuckles should be the same as the civic ex, you can just bolt the integra calipers right on (without swapping knuckles) and worrying about axles fitting
(the axles will fit even if you did swap knuckles though)
Old Jan 23, 2006 | 12:17 PM
Chrisfrom1986's Avatar
what integra brakes can fit on the 94 sol with D15B7? search only found this thread.
Old Jan 23, 2006 | 12:19 PM
you didnt search archived threads then
for that car, you need to use larger ex/si/integra sized knuckles or modify the caliper to use your dx sized knuckles
rodvang
Sep 7, 2006 03:50 PM
tylonalsnifnfool
Mar 23, 2006 07:50 PM
delsol31603
Jan 21, 2005 10:04 AM
