Hood lifting at high speeds - CRX / JDM SiR front end
Old Jan 17, 2006 | 07:54 AM
alexdog69's Avatar
Default Hood lifting at high speeds - CRX / JDM SiR front end
has anyone noticed that their JDM hood seems to love lifting and or flapping a bit at very high speeds? Past 130mph it is actually a little scary.
Has anyone found a good solution to this besides hood pins?
Does using the radiator support from the JDM ZC ED-style chassis with the SiR front bodywork help (as opposed to the slot/shim method most people employ to make the latch work with an EF radiator support on an ED chassis) ?
Or ... perhaps somehow modifying the spring on the latch ?
My front end fits rather nicely... and the hood closes easily and securely.. and doesn't have any play in it if I try to lift it by hand.... it also has the front weather stripping in tact so it isn't letting a shitton of air in like a CF hood w/o it...... but, regardless, on a windy day at high speed... it tends to flap a bit.....
I'd sure like to make it a bit more rock solid.....
I don't remember having this problem on my ED6 hatch... either with the OEM hood or the VIS CF ZC hood (w/o transferring the weatherstripping).... although, I did have some heat/sound insulation material on the left and right side inner panels of the hood.... which seemed to give it a nice tight fit and some damping when closed....
so I'm not quite sure what the best route to go with on this CRX is..... but hood pins are not an option for this car...
Old Jan 17, 2006 | 08:05 AM
crx_88_si's Avatar
my oem hood does this too, noticable around 75mph (120km/h). If youre really concerned and drive at that speed (ur nuts!) then i'd suggest hood pins (but be tasteful y0!)
Old Jan 17, 2006 | 08:23 AM
crxtreme89h's Avatar
Default Re: Hood lifting at high speeds - CRX / JDM SiR front end (alexdog69)
This is why you shouldn't go 130 in a CRX. Sorry, I don't have any suggestions. I just wanted to throw that in there. I can't say that I haven't driven that fast in a car, but holy crap! In a CRX? What are you doing at that speed? Are you at your peak at the drag strip or just cruising along on the Autobahn?
This reply not intended to be mean, just an inquiry as to what brings you to 130 in your CRX.
Old Jan 17, 2006 | 11:27 AM
drSquish's Avatar
The EF3 t-bar on the ED civic chassis with the SiR front end lets you keep your hood latch w/o modification
I know we all like to top out our EFs once and a while
Old Jan 17, 2006 | 11:36 AM
Immanuel's Avatar
Default Re: Hood lifting at high speeds - CRX / JDM SiR front end (drSquish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">I know we all like to top out our EFs once and a while </TD></TR></TABLE>
That is the truth
Old Jan 17, 2006 | 12:45 PM
STREETWERKZ's Avatar
Default Re: Hood lifting at high speeds - CRX / JDM SiR front end (1.6 DOHC ED9)
130 mph?
you live in Germany?
autobahn must be nice!
if you are doing this in the US, you deserve the hood to pop up.
Old Jan 17, 2006 | 01:35 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">The EF3 t-bar on the ED civic chassis with the SiR front end lets you keep your hood latch w/o modification
ive pined my speedo before, scary and stupid but we all try it at times
the ef3 tbar seems to be hard to find on its own
Old Jan 17, 2006 | 02:31 PM
fujiwara takumi's Avatar
i think the little stoppers under the hood can be adjusted to make the closure tighter. my miata has an aluminum hood and flaps over about 100, the spec miata is consistently in the 120's and flaps so bad its distracting. partenr wont let me use hood pins so i just deal with it.
Old Jan 17, 2006 | 02:47 PM
drSquish's Avatar
those stoppers don't do much. They're there mainly to raise it if you want...
Old Jan 17, 2006 | 02:52 PM
Default Re: (fujiwara takumi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fujiwara takumi &raquo;</TD></TR><TR><TD CLASS="quote">i. partenr wont let me use hood pins so i just deal with it.</TD></TR></TABLE>
do you mean " my partner" ? and your talking about a miata.
hummm
Old Jan 17, 2006 | 02:57 PM
Default Re: (Boosted Chemist)
hummm
Are you surprised that there are gay's on the internet? I don't think he/she is gay cause he/she said partner and Miata in the same paragraph.
Old Jan 17, 2006 | 03:00 PM
Default Re: (crxtreme89h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">
Are you surprised that there are gay's on the internet? I don't think he/she is gay cause he/she said partner and Miata in the same paragraph.</TD></TR></TABLE>
no i was just kidding, i dont care if they are gay or not, but u constantly hear about miatas being a "gay car" or a "car for gays"
before the flaming and hating begins i was just jokeing around
I usually ASSuME that partner means gay, i never call my gf my parter, lol
Old Jan 17, 2006 | 05:08 PM
drSquish's Avatar
I usually ASSuME that partner means gay, i never call my gf my part[n]er</TD></TR></TABLE>
Haha true that
Funny we mention gays and miatas. I was crusin today when I saw two guys wearing next to nothing in their miata. Or should I say their partner's miata.
Old Jan 17, 2006 | 05:09 PM
drSquish's Avatar
edit: somehow I double posted
tylojake
Dec 23, 2008 11:46 PM
CRX 2.0V-T
Dec 8, 2006 11:21 PM
Ef-er
17
Feb 23, 2005 06:51 AM
.ShawnD.
Sep 5, 2003 10:26 AM
xJ.SLOTHx
Apr 13, 2002 07:24 PM
