Water leak.. water in floorboard!
Old Jan 17, 2006 | 06:06 AM
green91's Avatar
Default Water leak.. water in floorboard!
Nearly every time it rains im getting water in my floorboard. Ive searched and it seems to be a common problem, but i havent been able to find a solution! Who else is having this problem.. and if so, how (if you have) did you remedy it? Thanks
Old Jan 17, 2006 | 06:36 AM
tangerinebeast's Avatar
it is your water drains in your moonroof sunroof that are clogd idk how to clean them never had the problem with mine
Old Jan 17, 2006 | 06:44 AM
green91's Avatar
My hatch is a DX, no moon roof
Old Jan 17, 2006 | 04:59 PM
bagpipe goatee's Avatar
my hatch is rusted where the rain gutters meet the windshield. pull the rubber coated metal strips out and check for rust there. i'm waiting for a new windshield before i fix the rust in mine. i just siliconed it for the time being.
Old Jan 17, 2006 | 05:27 PM
spoonfedcrx's Avatar
Default Re: Water leak.. water in floorboard! (green91)
it could be from a nunber of places. where on the floorboards? passenger side? driver's side? hatch area? find a friend and get a hose. have him hold the hose over the car. start at the windshield and work ur way around slowly. hit eh cowl too. make sure to go over the doors and hatch glass. removing some interior pieces may be necessary. water leaks can be a pain in the *** sometimes. post up what area the leak is coming from and may be able to help more.
Old Jan 17, 2006 | 05:45 PM
91zSi's Avatar
Default Re: Water leak.. water in floorboard! (spoonfedcrx)
Mine's leaking from both sides of the rear hatch hydraulic lift area.
Planning on just silicon around them.
Old Jan 31, 2006 | 07:10 AM
Stoich's Avatar
Default Re: Water leak.. water in floorboard! (91zSi)
Bump
Mine seems to fill up in the rear pass foot area
Old Jan 31, 2006 | 07:17 AM
boostinaintez's Avatar
Default Re: Water leak.. water in floorboard! (Stoich)
mine leaks freaking everywhere also, has anyone bought new weather stripping from a dealer and is it expensive.
Old Jan 31, 2006 | 09:02 AM
stdefhatch's Avatar
Default Re: Water leak.. water in floorboard! (boostinaintez)
im havin the same shitty problems too, mine just gets wet on the drivers side ride under my feet when it sits outside in the rain
Old Jan 31, 2006 | 09:25 AM
ArtyG's Avatar
Mine seems to get water in the rear driver side hatch area. I haven't really investigated, but at first glance it seems the stripping is a bit chewed up, so that may be a start if not silicone.
Old Jan 31, 2006 | 09:18 PM
Default Re: Water leak.. water in floorboard! (ArtyG)
anyone?
Old Feb 1, 2006 | 12:30 AM
Gheydm's Avatar
mine if you leave the sunroof sliding cover open and it rains water puddles up on top of the cover and when you go to close it water falls down on you, but i dont have any problems when its closed, so its mostly closed
Old Feb 1, 2006 | 11:00 AM
civbeater90's Avatar
Default Re: (Gheydm)
ok problem areas on the hatches with water in the hatch area-rear tailight seals and the rubber seal around the hatch.
Modified by civbeater90 at 1:47 AM 2/2/2006
Prudz_lude
Feb 8, 2016 11:19 AM
LeonardDB
14
Apr 12, 2011 08:57 AM
mnmsddy
11
Nov 29, 2009 09:12 PM
mycrxsi89
Aug 15, 2008 04:54 PM
JackAcc
Jun 20, 2003 09:10 AM
