soon to be 500+whp!
Old Jan 16, 2006 | 09:36 PM
ChrisRicketts's Avatar
Default soon to be 500+whp!
well, as some of you know i threw a rod through my built block this past summer....but now i'm putting together a whole new built motor. The new setup will have:
GE HD sleeves 87mm
Endyn Rollerwaves 9.0-9.5:1
Manley Rods
new OEM Honda oil pump
PNP Head with 1/2mm oversized valves, all ferrea components.
ARP studs
3" dp to 3" exhaust (converting to V-Band)
no a/c
70mm STR throttle body
rerouted intercooler piping to go like John D's (yea, I copy from the best way)
St00pid from AutoLogic, Inc. in Houston will tune the car.
still using Precision SC61, Precision intercooler (medium size), Precision 880cc injectors, Hondata s200/b, aeromotive fpr, str rail, SFP t3 manifold, greddy profec-b boost controller, greddy type-s BOV, TIAL 38mm W/G, tons of autometer gauges, slippery tires .
My goal is to make 500whp- i think this setup can do it pretty easily, but i don't want to make much more than that since this is my DAILY driver, and i can't afford to tear it up again. Wish me luck.........i should have her up and running within 8 weeks.
Old Jan 16, 2006 | 11:12 PM
Pullig's Avatar
Default Re: soon to be 500+whp! (ChrisRicketts)
hey hurry up and get this damn thing running i wanna see this thing move..... i moved back down here now so ill prolly be around on jackson sometime .. see you around
Old Jan 17, 2006 | 01:58 AM
The Weather Man's Avatar
Ahh - i'll have mine up this summer.
You HAVE to make a video - absolutely HAVE to. Dyno, and a street run. That thing is going to be a monster..........
So scared.............
Old Jan 17, 2006 | 04:28 AM
h22_crx's Avatar
nice lude
Old Jan 17, 2006 | 04:59 AM
mgags7's Avatar
sounds good...next up: get some slicks!!! do you have an lsd?
Old Jan 17, 2006 | 07:27 AM
Default Re: (mgags7)
no slicks, no lsd......just lots of tire spinning.
i'm afraid with slicks it will tear my driveshafts apart......(they are stock right now.)
i need some driveshaftshop.com axles, more heavy duty clutch, and lsd tranny. that will com this summer though.
I'll try to make videos if i can.
pullig- i NEVER drive on jackson anymore because i don't get off work early enough anymore. i may once i get this car running again, but hardly anyone is out anymore.
Old Jan 17, 2006 | 02:56 PM
john d
Guest
Posts: n/a
hmmm ge sleeves, endyn rollerwaves, manley rods... sounds alot like my set up haha 89mm > 87mm
let me know when your ready to come to dallas so we can run
Old Jan 17, 2006 | 04:48 PM
Chin0280's Avatar
Default Re: soon to be 500+whp! (john d)
good luck
Old Jan 18, 2006 | 07:12 AM
Default Re: soon to be 500+whp! (Chin0280)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm ge sleeves, endyn rollerwaves, manley rods... sounds alot like my set up haha 89mm &gt; 87mm
let me know when your ready to come to dallas so we can run</TD></TR></TABLE>
if you can't beat em...........you know.
yea your right- 89mm&gt;87mm, but 500+whp&gt;400whp! LOL
i know your setup can make a ton more power, why haven't you tried? with the t4 turbo you're running, you are just getting into it's efficiency range. that thing should really haul *** on the top end if you cranked up the boost some more and made around 550-600whp. I guess then you'd be breaking all kinds of **** though. I wanted to go to a t4 setup, but i don't have enough $ to do it right now, and build a new motor. maybe later......
Old Jan 18, 2006 | 07:33 AM
93civic_sedan's Avatar
like the setup but dont care for the wheels.
Old Jan 18, 2006 | 07:55 AM
john d
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">
i know your setup can make a ton more power, why haven't you tried? with the t4 turbo you're running, you are just getting into it's efficiency range. that thing should really haul *** on the top end if you cranked up the boost some more and made around 550-600whp. I guess then you'd be breaking all kinds of **** though. I wanted to go to a t4 setup, but i don't have enough $ to do it right now, and build a new motor. maybe later......</TD></TR></TABLE>
haha word. yeah my set up does have alot more potential but just as you said, ill end up breaking alot of stuff i dont have money to replace yet trying to get some sort of traction bar and still saving up for cheap rims/slicks. but its good to see your car is on its way back to life keep me posted
Old Jan 18, 2006 | 09:37 AM
Hawkze_2.3's Avatar
Control &gt; Power anyday.
Good luck, Chris.
Old Jan 18, 2006 | 10:14 AM
prelittlelude's Avatar
what is this amazing intercooler setup that you both have?
Old Jan 18, 2006 | 05:59 PM
ludesleep's Avatar
let me know when your ready to come to dallas so we can run</TD></TR></TABLE> I'll run you john
Old Jan 18, 2006 | 09:51 PM
vinuneuro's Avatar
Looks good! Any guesses as to how many psi will be needed to reach 500whp with this turbo?
Old Jan 18, 2006 | 11:00 PM
Default Re: soon to be 500+whp! (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote"> Looks good! Any guesses as to how many psi will be needed to reach 500whp with this turbo?</TD></TR></TABLE>
i imagine for my setup it will be around mid 20's. it really depends a lot on the compression ratio that you're running which for me is 9.0-9.5:1. john d made 400whp with just 10psi i think, but for my previous setup i only made 377whp with 20psi. but he also has a t4 setup. i think with things flowing more easily now through a PNP'd head with oversized valves, numbers will be reached a little more easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">what is this amazing intercooler setup that you both have?</TD></TR></TABLE>
it's not really amazing.....in fact, you would probably just think it looks normal, but since i had to figure out the first time where to put the i/c piping on the hot side, i went with the shortest route, and cut out the metal under my driver's headlight and just aimed the turbo down, brought a 90* across the bottom of the radiator, out the crappy hole that i made, and a SHARP restrictive unsmooth curver around the radiator and down a bit to the i/c........
the way john did it is makes much smoother turns and doesn't require much fabbing. i suppose many others have done it like this before john, but his is memorable to me, so i use his name. plus his setup looks VERY clean and professional. it goes with compressor outlet aiming up and a 90* across the top and then another 90* down through a hole cutout behind the drivers light, then just pull it around the front radiator support to the i/c. much simpler and cleaner. hopefully john doesn't care that i jack a couple of his pics and post them here to show you what i'm talking about.....
Old Jan 18, 2006 | 11:39 PM
PrecisionH23a's Avatar
I've been running all of my IC piping like that with preludes for a few years now. If the customer can't live without having a windshield washer reservoir, they don't deserve a turbo
Do any of you guys remember how the drag gen 2 IC piping ran back in the day? It was about 6-8 feet in length from the compressor to the drivers side IC inlet.
fmu's oWn.
Old Jan 19, 2006 | 06:11 AM
Default Re: soon to be 500+whp! (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
fmu's oWn.</TD></TR></TABLE>
talk about way back in the day! i remember exactly how they routed their piping.. Man that must have had some serious lag time to fill that whole ic setup and then presurize the mani..
chris-
setup is looking mean,
john-
id like to here how exactly or why you think you were able to make 400whp on 10psi?
Old Jan 19, 2006 | 07:06 AM
Default Re: soon to be 500+whp! (prelittlelude)
he made it on 10psi, but at a pretty high rpm (if i remember correctly).....his larger turbo (t4 sc61) doesn't have to boost as much to get more air back into the engine. more boost with his setup would be killer.
Old Jan 19, 2006 | 11:13 AM
john d
Guest
Posts: n/a
john-
id like to here how exactly or why you think you were able to make 400whp on 10psi? </TD></TR></TABLE>
WTF are you talking about, i have my dyno posted up.... i dont THINK im gunna make 400whp I ALREADY DID
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">he made it on 10psi, but at a pretty high rpm (if i remember correctly).....his larger turbo (t4 sc61) doesn't have to boost as much to get more air back into the engine. more boost with his setup would be killer. </TD></TR></TABLE>
i made it at the stock rev limit (i have a stock head )
ps- i do mind that you are jacking my pics!!! jk good luck w/ everything
Old Jan 19, 2006 | 12:05 PM
john-
id like to hear how exactly or why you think you were able to make 400whp on 10psi? </TD></TR></TABLE>
welcome to english class: you were able to - indicates past tense
rephrasing the question:
Id like to hear how exactly you were able to make 400 whp on 10 psi? and
Id like to hear why you think you were able to make 400 whp on 10 psi?
Old Jan 19, 2006 | 12:55 PM
Its really not that hard with a T4 setup.
Glad you guys are still getting along.
Old Jan 19, 2006 | 03:15 PM
john d
Guest
Posts: n/a
john-
WELCOME TO THE HONDA-TECH SPELLING BEE It's HEAR not HERE.
hear ( P ) Pronunciation Key (hîr)
v. heard, (hûrd) hear·ing, hears
v. tr.
To perceive (sound) by the ear: Can you hear the signal?
To learn by hearing; be told by others: I heard she got married.
To listen to attentively: Hear what I have to tell you.
To listen to in an official, professional, or formal capacity: heard the last witness in the afternoon.
To listen to and consider favorably: Lord, hear my prayer!
To attend or participate in: hear Mass.
Old Jan 19, 2006 | 03:39 PM
cr@zy wheel's Avatar
woow you're the man ... i really wanna see this thing taking off ...good luck man
Old Jan 19, 2006 | 04:47 PM
No offense, but your signature
Brakes will save lives. Change it to that.
